Matt Harwood Posted January 8, 2006 Share Posted January 8, 2006 do me a favour.... your Too tight...lol, and thats why you wanna buy robs fir a fiver, not because your friendly, and thats why you have more money than me. Pah! The only way I'd have more money than you is if you give me your wallet! And yes, I am tight! Link to comment Share on other sites More sharing options...
RobAce Posted January 8, 2006 Author Share Posted January 8, 2006 Pah! The only way I'd have more money than you is if you give me your wallet! thats no good any more though, cos terry has got the contence of it:nyah: Link to comment Share on other sites More sharing options...
Peter P Posted February 6, 2006 Share Posted February 6, 2006 Sorry to bump this back to life but just found out the E-Manage Ultimate I want won't work on my UK spec TT. Does anyone know any more about this or where I can find out? Tried e-mailing Greddy and checked their webpage but doesn't seem to say what the problem is?! Apparently it's being worked on by them as the US spec cars are also non-compliant?!?!?!?!?! I'm only relaying what Paul Whiffin has told me and presumably it's what the Greddy supplier he uses has told him?! :giveup: Why is it that everyone including some magazines that will stay unnamed rave about the UK cars?! Ok bigger injectors, gearbox cooler, glass headlights, bigger brakes, bonnet scoop but no aftermarket parts seem to work with them!!!!!!!!!!!! oh and insurance is cheaper but then modified examples aren't that much less!!!!!! Rant over and any help or advice always welcome! Cheers, Pete Link to comment Share on other sites More sharing options...
Alex Posted February 6, 2006 Share Posted February 6, 2006 It will work...worked on my VVTi (MAF based). Works on other UK specs. The eManage guru on here, IanC, knows more about the operation of the unit than ermm....anyone else bar the makers it seems. Even Mohd (mr. eManage in the US) doesn't yet understand the unit as much....but Ian's away for now and hasn't started playing with the really funky features on the EMU... Link to comment Share on other sites More sharing options...
Nic Posted February 6, 2006 Share Posted February 6, 2006 Do you have the part 15901504 Emanage Ultimate Injector Adapter 2 fitted, without this the EMU cannot control the fueling on the Supra Link to comment Share on other sites More sharing options...
Peter P Posted February 6, 2006 Share Posted February 6, 2006 The problem apparently is that it won't rev past 6,000 rpm. This is what Paul was told by a chap from the US. Not saying thats the case but what he was advised. As Paul says no way of knowing for sure without trying it!!!! Looks like i'll be a guinea-pig!!! Pete Link to comment Share on other sites More sharing options...
Alex Posted February 6, 2006 Share Posted February 6, 2006 The problem apparently is that it won't rev past 6,000 rpm. This is what Paul was told by a chap from the US. Not saying thats the case but what he was advised. As Paul says no way of knowing for sure without trying it!!!! Looks like i'll be a guinea-pig!!! Pete which guy? Is it Mohd? I know he was having troubles. Link to comment Share on other sites More sharing options...
Matt Harwood Posted February 6, 2006 Share Posted February 6, 2006 Hmmm, well, I'll let you know how I get on tomorrow. I'm supposed to be fitting on to Pig's UK spec. Personally, I can't see any reason why it won't work. But if I have a problem, I'll let you know tomorrow night. Link to comment Share on other sites More sharing options...
Peter P Posted February 7, 2006 Share Posted February 7, 2006 Cheers Matt if you could let me know how it all goes that'd be a big help!! Would save me the cost of getting mine all fitted only for it not to work!! Can think of a few other things that need to doing where the money can be spent if there is a problem at the moment. Will wait to hear from you. Pete Link to comment Share on other sites More sharing options...
Peter P Posted February 8, 2006 Share Posted February 8, 2006 I've PM'd you Matt hope that's ok? Just wondered how you got on? Cheers, Pete Link to comment Share on other sites More sharing options...
Matt Harwood Posted February 8, 2006 Share Posted February 8, 2006 No probs mate. As far as installation goes, no problems. There may well be a software issue though. I don't know any more than that yet, but I will report back as soon as I know more... Link to comment Share on other sites More sharing options...
Ian C Posted February 8, 2006 Share Posted February 8, 2006 Hallo Matt, I'm back home now so drop me a PM if you want to talk shop -Ian Link to comment Share on other sites More sharing options...
silver supra Posted June 15, 2006 Share Posted June 15, 2006 any news since that? cu Andy Link to comment Share on other sites More sharing options...
dandan Posted July 29, 2007 Share Posted July 29, 2007 Just to bump this and ask a question... The injector adaptor, can someone confirm it wires in between the ecu and the injector inputs on the EMU - like a pull up from the 12v line... Cheers Dan Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted July 30, 2007 Share Posted July 30, 2007 Just to bump this and ask a question... The injector adaptor, can someone confirm it wires in between the ecu and the injector inputs on the EMU - like a pull up from the 12v line... Cheers Dan Yes:) Link to comment Share on other sites More sharing options...
dandan Posted July 30, 2007 Share Posted July 30, 2007 Thank you. Link to comment Share on other sites More sharing options...
dandan Posted August 1, 2007 Share Posted August 1, 2007 OK guys I have a few other questions and would appreciate any input: I intend to run with the stock MAP sensor initially and then once I've routed the Greddy one into place I will switch to that (no mad rush to do that). I will initially be monitoring OEM water and air temp so knock connections are not needed right now. I have the AFR input harness coming from an AEM wideband setup. 1. Where can I get a USB cable to hook this up? I thought it came with one but obviously my memory deceived me. Is it a generic cable? 2. Are these jumer settings correct? 1. Open 2. Open 3. Open 4. Open 5. Open 6. Open 7. 1-2 8. 1-2 9. Open 10. 1-2 11. Open 12. Open 13. Open 14. Open 15. 1-2 16. Open 17. 1-2 18. Open 19. 1-2 20. 1-2 3. I'm initially running on OEM 440's so do I set the inj lag to 0.9 0.09 0.04 or 0.0 ? Everyone seems to have a different opinion. 4. Does the Greddy packaged software allow logging on a laptop for comparison later? If so can that data be exported to excel as comma separated values or similar? 5. Anyone know what the output on pin 62 (MAP) is when boost cut occurs - or what I should enter into the boost cut setup screen to act as a BCC? Many many thanks Dan Link to comment Share on other sites More sharing options...
rob wild Posted August 1, 2007 Share Posted August 1, 2007 OK guys I have a few other questions and would appreciate any input: I intend to run with the stock MAP sensor initially and then once I've routed the Greddy one into place I will switch to that (no mad rush to do that). I will initially be monitoring OEM water and air temp so knock connections are not needed right now. I have the AFR input harness coming from an AEM wideband setup. 1. Where can I get a USB cable to hook this up? I thought it came with one but obviously my memory deceived me. Is it a generic cable? Its a standard A-B USB cable that i use. 2. Are these jumer settings correct? 1. Open 2. Open 3. Open 4. Open 5. Open 6. Open 7. 1-2 8. 1-2 9. Open 10. 1-2 11. Open 12. Open 13. Open 14. Open 15. 1-2 16. Open 17. 1-2 18. Open 19. 1-2 20. 1-2 They look similar to what im using (will check again for you) 3. I'm initially running on OEM 440's so do I set the inj lag to 0.9 0.09 0.04 or 0.0 ? Everyone seems to have a different opinion. After using a couple of different setting i found that 0.9 worked the best i.e. the car started as normal. 4. Does the Greddy packaged software allow logging on a laptop for comparison later? If so can that data be exported to excel as comma separated values or similar? Yes it allows data logging and yes you can export the data. 5. Anyone know what the output on pin 62 (MAP) is when boost cut occurs - or what I should enter into the boost cut setup screen to act as a BCC? Not sure i will check my map for you Link to comment Share on other sites More sharing options...
dandan Posted August 1, 2007 Share Posted August 1, 2007 You're a good man Rob - thanks mate.. Link to comment Share on other sites More sharing options...
tDR Posted August 1, 2007 Share Posted August 1, 2007 MAP output when boost cut occurs is 4.4v Do you need to set it to act as a BCC when you're gonna be pulling fuelling anyways? IE you'll lower the voltages below 4.4v on the fuelling table, apart from cells where the boost is above the desired level - giving you the safety net of still having boost / fuel cut but at a level you choose. That's the way I've mapped my MAP2 ECU. Cheers, Brian. Link to comment Share on other sites More sharing options...
dandan Posted August 2, 2007 Share Posted August 2, 2007 Brian - that would be the case if i was fiddling with that incoming airflow signal. I don't intend to map it like that at all. I will be adding and subtracting duty cycle directly without ever touching the airflow signal. So looks like I'll put in 4.35v or something like that for the boost cut threshold. Did you manage to double check those jumpers Rob? Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 2, 2007 Share Posted August 2, 2007 It won't make any difference to the boost cut, just set it to 4.40V and you can adjust whatever you want in the fuel maps:) Just had a look at the jumper settings, and AFAIK mine are all set to factor defaults except for J8 which is set to 2.3 12V for ign. Link to comment Share on other sites More sharing options...
dandan Posted August 2, 2007 Share Posted August 2, 2007 It won't make any difference to the boost cut, just set it to 4.40V and you can adjust whatever you want in the fuel maps:) What won't make a differnce TR? All I wanted to know ref. that MAP voltage was what to input in the boost cut threshold table so the EMU would be my boost cut controller as I won't have one after I sinstall the EMU. 4.4V is it then? Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 2, 2007 Share Posted August 2, 2007 Sorry, thought you where thinking that if you're not using the airflow/map adjustment, the boost cut setting wouldn't work? Yes MAP voltage of 4.4V limit, will prevent boost/fuel cut. Link to comment Share on other sites More sharing options...
dandan Posted August 2, 2007 Share Posted August 2, 2007 Sorry, thought you where thinking that if you're not using the airflow/map adjustment, the boost cut setting wouldn't work? Yes MAP voltage of 4.4V limit, will prevent boost/fuel cut. Cool - good man. Link to comment Share on other sites More sharing options...
