Mark Ayling Posted June 9, 2003 Share Posted June 9, 2003 Chaps.... I was attempting to replace the fag-lighter in my car yesterday, as it doesn't work. There is (was!) definitely power to it, as my radar detector is hardwired to the same power supply. However, I stupidly shorted it out when removing the old one, I guess I've just blown a fuse but none of the ones under the engine bay have gone - any idea where the fuse for this lives? I had a look under the driver's-side kick-panel (as I thought there were more fuses under there) but couldn't see any "normal" fuses.... Any help appreciated - I have to get this fixed by Thursday as I'm going to Le Mans and we really need to plug our fridge in, can't be drinking warm beer all weekend.... TIA, Mark. Quote Link to comment Share on other sites More sharing options...
mos Posted June 9, 2003 Share Posted June 9, 2003 Get a torch and look above the drivers side kick panel and you should see a black cover that unclips, the fuses are inside there. You dont actually need to remove the kick panel as its above the panels top lip Quote Link to comment Share on other sites More sharing options...
Steve W Posted June 9, 2003 Share Posted June 9, 2003 here you go.... although, it says it does the A/C and the Airbags TOO ? ? > > Quote Link to comment Share on other sites More sharing options...
Mark Ayling Posted June 9, 2003 Author Share Posted June 9, 2003 Cheers guys This is a classic example of why I would be willing to pay more than £10 to be a member of this site! 15 minutes and I have an answer to my question with diagrams - fantastic Quote Link to comment Share on other sites More sharing options...
Steve W Posted June 9, 2003 Share Posted June 9, 2003 WHAT diagram ? ? I SKETCHED that from memory........ [just showin' off me Owners Manual...... it's not much use for anything else ! ! ] Quote Link to comment Share on other sites More sharing options...
Mark Ayling Posted June 9, 2003 Author Share Posted June 9, 2003 Quote Link to comment Share on other sites More sharing options...
Terminator Posted June 9, 2003 Share Posted June 9, 2003 Steve if Iam not mistaken Mark is offering a finders fee. Quote Link to comment Share on other sites More sharing options...
Mark Ayling Posted June 10, 2003 Author Share Posted June 10, 2003 Originally posted by Terminator Steve if Iam not mistaken Mark is offering a finders fee. LOL yep - if you can find the fee you can have it.... Quote Link to comment Share on other sites More sharing options...
400BHP Posted June 12, 2003 Share Posted June 12, 2003 Here's a challenge for you then, where is the relay that controls the headlight washer pump? Its not in the main fusebox. Any ideas? Quote Link to comment Share on other sites More sharing options...
Steve W Posted June 12, 2003 Share Posted June 12, 2003 mmmmm.... can't see a RELAY for them ? ! (and there probably should be - but if the current's not too bad, doesn't HAVE to be ?!) BUT, they run thru No.45 MAIN fuse (Under Bonnet) and No.1 BLADE fuse (Kick-Panel) > > > Quote Link to comment Share on other sites More sharing options...
Steve W Posted June 12, 2003 Share Posted June 12, 2003 .....and..... > > > Quote Link to comment Share on other sites More sharing options...
Steve W Posted June 12, 2003 Share Posted June 12, 2003 (but then......... as I DON'T HAVE ANY I couldn't really give a Monkey's Left Te**icle ! ! ! ) Quote Link to comment Share on other sites More sharing options...
Thorin Posted June 12, 2003 Share Posted June 12, 2003 Originally posted by Steve W (but then......... as I DON'T HAVE ANY I couldn't really give a Monkey's Left Te**icle ! ! ! ) You don't want them dildo's on the front of your car anyway Steve, they slow you down you know! Quote Link to comment Share on other sites More sharing options...
Steve W Posted June 12, 2003 Share Posted June 12, 2003 YEAH, but, could use 'em as BUMPERS..... you must hear a little 'CRUNCH' ~3inches from the MAJOR one ? ! ['sides, could have used the circuit/bottle for an I/C spray:devil: ...for those HOT Pod' days ! ! ] Quote Link to comment Share on other sites More sharing options...
400BHP Posted June 12, 2003 Share Posted June 12, 2003 Yeah it definately has a relay in line somewhere, its not under the bonnet because I have removed then one at a time and shorted the switched circuit to see if the pump runs and it doesn't. Also the wiring to the switch is definately just control circuit gauge wire, no where near the size of the pump wiring, which is quite a large gauge, the pump has a large outlet and is quite a hefty motor, its about 3 times the size of the windscreen washer pump. Im gonna try the relays under the dash soon, when I get chance. Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted June 13, 2003 Share Posted June 13, 2003 I think they are the ones under the nearside headlight and behind the front bumper. Quote Link to comment Share on other sites More sharing options...
400BHP Posted June 13, 2003 Share Posted June 13, 2003 Thats what I thought but unfortunately no, they are air con and traction control i belive from memory, it had the designation written on them. Quote Link to comment Share on other sites More sharing options...
Branners Posted June 13, 2003 Share Posted June 13, 2003 you did take the comments about having your headlamps on when operating the washers seriously didnt you? JB Quote Link to comment Share on other sites More sharing options...
400BHP Posted June 13, 2003 Share Posted June 13, 2003 Errr yes john, Headlamps and Ignition on, still no voltage at the pump. I need to locate the relay so that I can see if the switching voltage is present. Quote Link to comment Share on other sites More sharing options...
