Guest kennyf Posted November 3, 2005 Share Posted November 3, 2005 Would 8.5J with track spacers; http://www.performancealloys.com/alloy_wheel_spacers.asp give the car the same handling set up as with 9.5J or just the appearance of a wider rear but without the handling? Link to comment Share on other sites More sharing options...
Guest kennyf Posted November 4, 2005 Share Posted November 4, 2005 Any ideas anyone? Link to comment Share on other sites More sharing options...
Ian W Posted November 4, 2005 Share Posted November 4, 2005 i personally wouldn't use spacers at all mate, no matter how good they claim to be. Link to comment Share on other sites More sharing options...
absz Posted November 4, 2005 Share Posted November 4, 2005 just a word of caution. i bought some wide spacers for my car. but noticed that the fitment was not quite right as when the spacers were bolted on to the hub there was a gap between the hub and spacer, which is only noticable when checking using a feeler gauge. so had the centre bore re-machined on all 4 spacers. also the nyloc nuts supplied with the spacers did't seem like good quality. Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 4, 2005 Share Posted November 4, 2005 kennyf said: Would 8.5J with track spacers; http://www.performancealloys.com/alloy_wheel_spacers.asp give the car the same handling set up as with 9.5J or just the appearance of a wider rear but without the handling? DO NOT use spacers, tjhey are a total cock up, buy wheels that fit, in every respect. Of (say) 10 MKIV's i see with aftermarket wheels you can bet only one will have ones that actually fit correctly. maybe even a lower percentage than that. And no, 8.5 rims with spacers are totally different to 9.5 inch rims in every respect. Link to comment Share on other sites More sharing options...
Guest kennyf Posted November 4, 2005 Share Posted November 4, 2005 Ok no spacers then but would this set up fit a mkiv Fronts 18x8 - ET 30 Rears 18x10 - ET 25 with a PCD of 114.3? Link to comment Share on other sites More sharing options...
RICHARDA Posted November 5, 2005 Share Posted November 5, 2005 Ken, Try and stick as near as poss to stock offset of 50mm front and rear. I am running 30mm front and 40mm rear but this will only ever be a compromise. PCD is correct AFAIK. HTH Rich Link to comment Share on other sites More sharing options...
