Gazboy Posted November 3, 2005 Share Posted November 3, 2005 Mate of mine lives in Seattle, has a prob with temps: have to go find a cure for my truck and its odd temperature gauge behaviour... what do you reckon to this: cruising along temp is fine, then it goes all the way up to the top then back to normal. in about 5 seconds... but thats all it does, the needle goes to the red bit then as quick as it got there goes back down... im guessing it could be a blocked pipe, temp sender, thermostat or even just a rad flush.. who knows... ----------------- Any ideas? Link to comment Share on other sites More sharing options...
TrickTT Posted November 3, 2005 Share Posted November 3, 2005 Gauge or sender only. No way the water temp could fluctuate that quickly. Its a regular problem on our Scanias at work Link to comment Share on other sites More sharing options...
Ian C Posted November 3, 2005 Share Posted November 3, 2005 My Granada used to do this - the Ford garage said it was the balance resistor on the back of the gauge. I swapped them and it still did it. But it wasn't the actual water temp... -Ian Link to comment Share on other sites More sharing options...
