michael parker Posted November 1, 2005 Share Posted November 1, 2005 As it's getting colder i checked the anti freeze situation out, and theres seems to be a distinct lack of it. Just want to check if i know how to do it, cos of the different cars i've had it's been slightly different on each one. Drain the old fluid out using bottom rad pipe or drain tap, Flush through rad flush, reconnect pipe/tap and start to fill up with 50% demin water and 50% anti freeze (red toyota for life?). Do you then have to run the engine till it heats up and the stat operates and allows you to continue to fill up the coolant? Then keep doing this until it's full? Does this sound about right? or am i missing something? Thanks in advance:thanks: Link to comment Share on other sites More sharing options...
supRo Posted November 1, 2005 Share Posted November 1, 2005 Toyota Forlife Red is ready to pour in - you don't dilute it Link to comment Share on other sites More sharing options...
michael parker Posted November 1, 2005 Author Share Posted November 1, 2005 But is what i said correct, other than the dilution? Link to comment Share on other sites More sharing options...
supRo Posted November 1, 2005 Share Posted November 1, 2005 These links will help, I'm personally not sure as I've not changed it myself... http://www.mkivsupra.net/vbb/showthread.php?t=29556&highlight=coolant+change http://www.mkivsupra.net/vbb/showthread.php?t=27807&highlight=coolant+change Link to comment Share on other sites More sharing options...
michael parker Posted November 1, 2005 Author Share Posted November 1, 2005 Thanks alot:thumbs: I did use the search button, though to no avail, i swear my search button doesn't give me the same access that everone else gets:whistle: :) Link to comment Share on other sites More sharing options...
