List of engine parts i need!! (if u can help with part numbers post as well)
Whitesupraboy2
Ok guys List of parts ive been told i need,(may be more as told the cam belt jumped 4 teeth but hopefully im safe on that):
Cooling Fan Pulley
Crank Pulley
Alternator
Crank Pulley Bolt
Lower Cam Belt Cover
Aux Belt Tensioner
Aux Belt (got)
Cambelt Tensioner Pulley
Cambelt Tensioner Arm
Cambelt Tensenior Pully arm Bolt
Cambelt Sprocket (crank)
Cam belt
Spark Plugs for NA (which type)
oil filter
If you have any part numbers id be gratefull. I am an NA please remember. If you have any of these parts PM me, will be most appreciated. Im hunting for the bits ASAP.
Cooling Fan Pulley
Crank Pulley Bolt
Cam belt
I have the above items on my spare VVTi TT engine. If you can find out if they're the same as the NA I'll sort them out for you.
Let me know if you want any of them.
Cooling Fan Pulley
Crank Pulley
Alternator - ebay.com item no: 8010860072
Crank Pulley Bolt
Aux Belt Tensioner
Aux Belt (got)
Cam belt
Spark Plugs for NA (which type) - Dazsir
oil filter - about £7.00 including gasket from toyota, just tell them its a lexus GS300.
(updated)
Hi mate, ill check all this tomorrow with the guy from toyota. Thanks again
Thanks to everyone from this thread. Is this from engine you toasted mate, i dont like taking peoples parts that are on engines ready to go in 'just incase' i feel guilty if they are needed
(updated list)
Cooling Fan Pulley
Crank Pulley
Alternator (got)
Crank Pulley Bolt
Aux Belt Tensioner
Aux Belt (got)
Cam belt
Spark Plugs for NA (which type) - Dazsir (got)
Jake - do you have model number /chassis number incase i need it when i call them at lunch PM if you want thanks mate
Originally Posted by whitesupraboy2
Cooling Fan Pulley
Crank Pulley Bolt
Cam belt
All are compatable except for Cambelt sprocket. So if it ok with you mate,ill take the lot! If the cam belt isnt new though dont worry bout that, as ill buy a new one. Im gonna PM you now mate
(updated list)
Cooling Fan Pulley (jake - got)
Crank Pulley
Alternator (Absxxx got)
Crank Pulley Bolt (Jake - got)
Aux Belt Tensioner
Aux Belt (got)
Cambelt Tensioner Pulley (Jake - got)
Cambelt Tensenior Pully arm Bolt (Jake - got)
Cam belt
Anything anyone can help with feel free to post or PM me
thanks again to all
  • 2 weeks later...
