Help - No Heat!!!
VIL
First chilly morning, Christmas is on its was! So I thought I would use the heater for the first time this year.
Turned it up to hot and ........ only a tiny amount of warm air :(
If I give her some stick then I do get a burst of warm air but if its idling then its almost cold.
Is this a blocked matrix?
If so whats the best way to sort it out? I cant be driving to work with a hat, coat and gloves on all winter.
My Puma did this last year as well. My first thought was my heater matrix. But it turned out to be a buggered thermostat which was lucky.
I don't know how to check though.........
However
As a temporary measure you can buy a heater that plugs into your cigerette lighter...............:D
could be as simple as someone has not bled the radiator properly. i didnt do it properly in my old car and was fecking freezing all winter..... either bleed the the radiator or buy a new car like i did....SOOP!!!
From what i've herd, it dose'nt want to be the Matrix :thumbdown
Good luck thought mate ! I had a Renault 19 16v a few years ago and the heater never used to work, winter mornings it had thick ice on the inside of the windscreen. :eek: Don't freeze
Could be a number of things:
- blocked pipes, (bars radiator flush, halfrauds @ about
£4.99)
- Could be heater matrix, try a search on here and flush the pipes with a hosepipe or px washer, (be careful though if the matrix is on it's way out and you blast HP down it, you could finish it off!
-Could be air mixture flap only opening partially.
-Insufficiently bled radiator.
-thermostat?
