Slip control light flashing
Mike25tt
The engine management light always comes after been on the road for about 15mins and the slip control light then starts to flash. Ive tried pressing the slip control button to turn it on or off but this has no effect.
Has anyone had this problem or know how to sort it out?:shrug:
On the side of the throttle body (labelled ETCS) there is a plastic cylindrical box this can sometimes come lose try taking it of the putting back on then do a ECU reset.
You need to be mindfull that it has to be in the exact position. Are you Auto if so then the O/D light may be flashng aswell.
Hope this helps
Ive also noticed that when I switch Slip control off it will indicate in amber on the dash, but when I switch it on it doesn't indicate on the dash. I know that the green light works because both lights are on when the ignition is turned on. Any help would be great.
