eyefi Posted October 29, 2005 Share Posted October 29, 2005 a question for the non recirculated (dump to atmosphere or dump tube) wastegate folk at wot, fully open wastegate, will my afr reading still be accurate in the downpipe? i would think it should be, same source, just less of it? Link to comment Share on other sites More sharing options...
bromy Posted October 29, 2005 Share Posted October 29, 2005 Edited: My mistake in downpipe after wastegate Link to comment Share on other sites More sharing options...
b_have Posted October 29, 2005 Share Posted October 29, 2005 Yes it would be. Nothing to do with volume. My sensor is also in the did pipe. Think the sensor would overheat anywhere near the wastegate. Link to comment Share on other sites More sharing options...
bromy Posted October 29, 2005 Share Posted October 29, 2005 Yes it would be. Nothing to do with volume. My sensor is also in the did pipe. Think the sensor would overheat anywhere near the wastegate. So has mine been installed too close to the turbo? Link to comment Share on other sites More sharing options...
bromy Posted October 29, 2005 Share Posted October 29, 2005 So has mine been installed too close to the turbo? ? Link to comment Share on other sites More sharing options...
b_have Posted October 29, 2005 Share Posted October 29, 2005 Maybe, Guess it depends on the sensor, I use the innovate wb kit with a Bosch sensor. Doesnt like temps>500C. Link to comment Share on other sites More sharing options...
bedlam Posted October 29, 2005 Share Posted October 29, 2005 They should stay constant even with a WB stuck up the rear of the exhaust ours where rock solid.... And that WB looks to close to the turbo, i believe most will want about 3 feet from the manifold,or they burn out quick. Andy Link to comment Share on other sites More sharing options...
SimonB Posted October 29, 2005 Share Posted October 29, 2005 ? Well hey, maybe I'm missing something, but that's after the wastegate, it's in the downpipe after the turbo isn't it? Link to comment Share on other sites More sharing options...
b_have Posted October 29, 2005 Share Posted October 29, 2005 I would guess he means the wastegate is plumbed back into the downpipe (ie no screamer) after the sensor. Link to comment Share on other sites More sharing options...
bromy Posted October 29, 2005 Share Posted October 29, 2005 I would guess he means the wastegate is plumbed back into the downpipe (ie no screamer) after the sensor. Do you mean me charlie?, then no mine is to air Link to comment Share on other sites More sharing options...
SimonB Posted October 29, 2005 Share Posted October 29, 2005 Do you mean me charlie?, then no mine is to air Then you're in the same situation as eyefi, the wastegate will vent exhaust gas that would otherwise go through the O2 sensor. Link to comment Share on other sites More sharing options...
Miguel Posted October 29, 2005 Share Posted October 29, 2005 ? That is absolutely fine where it is:thumbs: Link to comment Share on other sites More sharing options...
