Prof. Monkey Posted October 28, 2005 Share Posted October 28, 2005 Hooray! Fitted my Thor DSC + speedo converter. Works a treat! Thanks Paul E, now I can outrun a punto, finally! Quote Link to comment Share on other sites More sharing options...
edd_t Posted October 28, 2005 Share Posted October 28, 2005 are all j-spec limited when they come in to the country? i hit 120 (along a private round near a airfield). does this mean mines reading wrong, cos i dont think it has been delimited or anything! Quote Link to comment Share on other sites More sharing options...
Ian R Posted October 28, 2005 Share Posted October 28, 2005 Mine was delimited already when it came over Quote Link to comment Share on other sites More sharing options...
Prof. Monkey Posted October 28, 2005 Author Share Posted October 28, 2005 J-Specs are limited within Japan to 112mph, some will go slightly over. Pull up the carpet in the passenger side at the front, there is a plastic plate, remove that with a socket (10mm) and you will see the ECU, the connector at the bottom, the 2nd wire at the top will have a wire running from it if it has a delimiter. The wire you are looking for into the ECU will be pink. Does your speedo work in miles or kmh? If it works in miles it might have had a delimiter fitted! Quote Link to comment Share on other sites More sharing options...
irfan_habib Posted October 28, 2005 Share Posted October 28, 2005 are all j-spec limited when they come in to the country? i hit 120 (along a private round near a airfield). does this mean mines reading wrong, cos i dont think it has been delimited or anything! It may display 120 on the speedo, yet in actual fact the true speed is probably about 10% less. So around 112. Quote Link to comment Share on other sites More sharing options...
edd_t Posted October 28, 2005 Share Posted October 28, 2005 aha, cheers. i will check at the weekend Quote Link to comment Share on other sites More sharing options...
sooper-supra Posted October 28, 2005 Share Posted October 28, 2005 ill need to buy one of those how much? Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted October 28, 2005 Share Posted October 28, 2005 Its a well known fact that J-spec supra speedo's read 120 mph at 112 mph before the proper delimiter conversion box is fitted. Quote Link to comment Share on other sites More sharing options...
adi2009 Posted October 28, 2005 Share Posted October 28, 2005 a bit of a . This may sound odd but after my NA-TT swap the speedo started reading in Miles. the only mod i did was fitting the Greddy BCC (boost cut controller)??? how is this possible Cheers Quote Link to comment Share on other sites More sharing options...
edd_t Posted October 28, 2005 Share Posted October 28, 2005 lol i was just chickening out at that speed! but maybe my delimiter did cut in Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted October 28, 2005 Share Posted October 28, 2005 a bit of a . This may sound odd but after my NA-TT swap the speedo started reading in Miles. the only mod i did was fitting the Greddy BCC (boost cut controller)??? how is this possible Cheers Did you change the speedo as well? Apparently they are different and the signal from the NA ECU is different to the one from the TT ECU. Well thats what I was told when I considered that task. Quote Link to comment Share on other sites More sharing options...
adi2009 Posted October 28, 2005 Share Posted October 28, 2005 I thought the RPM signal was what's different and would need the TT's Revmeter. Well my RPM meter doesnt work at all though so that must be true. When I m topped out in 2nd gear the speedo reads 60, in my NA second gear topped out used to be about 100kmph. Thats why i assumed that it may be reading in Miles now. Quote Link to comment Share on other sites More sharing options...
SupraWoman Posted October 28, 2005 Share Posted October 28, 2005 Mine is J-spec and it wasnt delimited - I've done 155 and someone else in it done 165. well it was last summer, didnt get to drive it this summer.. Quote Link to comment Share on other sites More sharing options...
Lucifer Posted October 29, 2005 Share Posted October 29, 2005 J-Specs are limited within Japan to 112mph, some will go slightly over. Pull up the carpet in the passenger side at the front, there is a plastic plate, remove that with a socket (10mm) and you will see the ECU, the connector at the bottom, the 2nd wire at the top will have a wire running from it if it has a delimiter. The wire you are looking for into the ECU will be pink. Does your speedo work in miles or kmh? If it works in miles it might have had a delimiter fitted! Not all cars are delimited in this way tho. Quote Link to comment Share on other sites More sharing options...
