JCresswell Posted May 27, 2003 Share Posted May 27, 2003 Can ANyone help, i have done a search on the site about changing the radiator fluid (mine is a bit brown), all the info is there but can anyone tell me if there is a rad bleed screw, and if so where is it, I have air in the system at the moment, (i can hear it) i got rid of most but there is still some in it>? Other cars ive used to own had rad bleed screws at the highest point of the cooling system, is there one on the supra (mkiv tt by the way). Any advise? or help? Link to comment Share on other sites More sharing options...
Andrew Posted May 27, 2003 Share Posted May 27, 2003 http://www.mkiv.com/manual/manualtt/coolant_replacement/index.html Need to do mine soon too. Link to comment Share on other sites More sharing options...
JCresswell Posted May 27, 2003 Author Share Posted May 27, 2003 MMM, thanks mate this helps alot, it looks like you use the rad capto bleed it??????? is this what you think or am i looking at it wrong!!! Link to comment Share on other sites More sharing options...
Andrew Posted May 27, 2003 Share Posted May 27, 2003 Seems that way yes. This should tell you all you need to know, explains the bleeding process too. http://www.mkiv.com/techarticles/coolant_flush/index.html Link to comment Share on other sites More sharing options...
Alex Posted May 27, 2003 Share Posted May 27, 2003 Face the car Right hand side Back of the radiator Plastic butterfly screw with a pipe located directly below it. Undo the screw, fluid comes out of the pipe. Undo the rad cap first. Link to comment Share on other sites More sharing options...
