D2 Coilover Group buy??
daveburwash
36-way adjustable, compression and rebound.
Mono-tube design for maximum performance.
All shock absorbers are gas and oil separately (30% Nitrogen 70% Oil) monotube design that can reduce the oil leaking defects.
The dampers can be disassembled, and rebuilt to meet all requirements. The shock absorber also includes high-performance front pillow ball top mount (Mcpherson Type) to complete this unique products.
Our shock absorbers are made by lightweight 6061 aluminium alloy material and have done with T6 for increasing hardness, and forming by forging and anodized to avoid losing colour.
All models can be lowered up 120mm more than the original height when shock absorber is fitted.
Linear rate spring with chrome silicon metal alloy springs, available from 3.5-22 kg/mm.
Top turning adjuster to adjust damper and rebound up to 36 ways. All shock absorbers are adjustable for both compression and rebound.
Teflon thread coated to prevent rust and corrosion.
Our shock absorbers are qualified by "World ARTC" for million circles with no liquid leakage, qualified as race proven equipments.
1 year limited warranty.
Spring rates F 15kg R 8kg
Eibach Pro-Kit:**....165lbs(2.9k)....140lbs(2.5k)....1.2f / 1.2r
Espelir ASD:............263lbs(4.7k)....319lbs(5.7k)....79f / .79r
Espelir GT:..............308lbs(5.5k)....330lbs(5.9k)....1.7f/ .98r
Ralliart:...................280lbs(5.0k)....307lbs(5.5k)....0.5f / 0.5r
RSR:**....................224lbs(4.0k)....280lbs(5.0k)....1.4f / 1.4r
RSR Ti2000..............280lbs(5.0k)....336lbs(6.0k)....1.4f / 0.8r
Stock(USDM):..........180lbs(3.2k)....225lbs(4.0k)......STOCK
Tanabe GP210:.......256lbs(4.6k)....319lbs(5.7k)....1.5f / 1.0r
Tein High Tech:**...196lbs(3.5k)....268lbs(4.8k)....1.4f / 0.3r
Tein S Tech:**........212lbs(3.8k)... 291lbs(5.1k)....2.0f / 0.9r
Coilovers:
APEXI PRO:..............560lbs(10.K).....560lbs(10.K)....Adjustable
CUSCO Zero 1:........392lbs(7.0K).....280lbs(5.0k)....Adjustable
CUSCO Zero 2:........392lbs(7.0K).....280lbs(5.0k)....Adjustable
CUSCO Zero 2R:......392lbs(7.0K).....280lbs(5.0k)....Adjustable
HKS Hypermax II:....392lbs(7.0k).....336lbs(6.0K)....Adjustable
HKS Hypermax RS....336lbs(6.0K).....280lbs(5.0k)....Adjustable
HKS Kansai Tarmac:.448lbs(8.0K).....448lbs(8.0K)....Adjustable
HKS Kansai Track:....896lbs(16.K).....784lbs(14.K)....Adjustable
HKS Performer:........392lbs(7.0k).....336lbs(6.0k)....Adjustable
HKS PRO:.................672lbs(12.K).....672lbs(12.K)....Adjustable
JIC FLT A2:...............560lbs(10.K).....504lbs(9.0K)...Adjustable
OHLINS FLAG L:.............ANy ..............Any ...............Adjustable
OHLINS R/T:.............250lbs(4.4k).....310lbs(5.5k)....Adjustable
Ralliart:....................336lbs(6.0K).....336lbs(6.0K)....Adjustable
Tein Basic:...............392lbs(7.0k).....336lbs(6.0K)....Adjustable
Tein Flex:.................504lbs(9.0K).....448lbs(8.0K)....Adjustable
Tein SS:...................392lbs(7.0k).....336lbs(6.0k)....Adjustable
Tein RA:...................672lbs(12.K).....504lbs(9,0K)....Adjustable
Tein HA:...................504lbs(9.0K).....392lbs(7.0K)....Adjustable
Tein HT:...................896lbs(16.K).....672lbs(12.K)....Adjustable
ZEAL:.......................336lbs(6.0K).....280lbs(5.0k)....Adjustable
ZEAL Also:...............448lbs(8.0k).....392lbs(7.0k)....Adjustable
** = progressive rate
Just wanted to say I have these fitted to my supe and she flies round corners. Really would recommend them. Did have Spax struts with eibach springs but these wipe the floor with them, and for the money my grin is twice as big :D
How do you find the spring rates Tom??
Coilovers:
Espelir ASD:............263lbs(4.7k)....319lbs(5.7k)....79f / .79r are these the right way round f and r
Question for the more technical folk. I have heard that the hks hypermax II ride very well and are not too harsh as with the tein flex wheras the cusco2
are very harsh - but the spring rates are higher for the hks and teins - so is this down to the dampers or just subjective difference of opinion ?
Coilovers:
Personally speaking I dont rate the Hypermax II's
