Turbo Gaskets - Source??
Thor
Guys I need a source for turbo gaskets.
Specifically I need the ones for the oil feed & return on a Garrett T4 type. If anyone has a source I need two of each. The dimensions for the centre to centre of the fixing holes are as follows:
Feed 38mm
Return 50mm
These are the oval type gaskets. The feed has a small hole in the centre ( around 10mm) & the return has a rectangle 20mm x 15mm
Any help greatly appreciated.
