Pectel T6m 2000
GeordieSteve
Wasnt pectal setup by a bunch of ex motec guys?
Great units and as far as i am aware they even do drop in replacements for scoobies and evos, dunno if one has been used on a supra yet but my mapper highly recommends them.
Pectel was set up by my boss :)
I'm an embedded software engineer for Pectel, and as it happens, for the last three years most of the software development work on this ECU has been done by me.
I don't recall whether it's been used on a supra before, but I suspect it would be quite a bit of effort to run it on the supra engine. Anyone know what the crank/cam pattern is on the supra?
Serial or CAN (via parallel port adapter). I think I tried it successfully with a USB->serial converter a while ago.
Groooooan.
How many laptops do you see with hardware serial com or parallel ports these days? USB serial dongles and software COM drivers are very hit and miss. Whilst you're rewriting the software you should SERIOUSLY consider USB functionality.
