terribleturner Posted October 22, 2005 Share Posted October 22, 2005 Ok i know the rule of thumb of 1cc to 1hp and to help with my J-spec rail i think i'm gonna drop some 650's in. But what sort of bh curve qwill this give me?? as in the highest and lowest bh that these are capable of handaling?? Quote Link to comment Share on other sites More sharing options...
terribleturner Posted October 24, 2005 Author Share Posted October 24, 2005 Bump Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted October 24, 2005 Share Posted October 24, 2005 that rule of thumbs is based upon a certain fuel pressure mate, and a dangerous game. Quote Link to comment Share on other sites More sharing options...
terribleturner Posted October 24, 2005 Author Share Posted October 24, 2005 Would you think then to Run a T66 or 67 i'd be fine with 650's or should i get slightly higher?? I'm thinking of going with the fuel package you guys do Terry and just want to know about the best injectors for the job. Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted October 24, 2005 Share Posted October 24, 2005 The answer lies it your anticipated Max boost, and how you are going to control them Quote Link to comment Share on other sites More sharing options...
JohnA Posted October 24, 2005 Share Posted October 24, 2005 The rule of thumb also assumes a max duty rate (that you may or may not exceed) and a target AFR at full power, which you may or may not adhere to. It's a rough estimate so you don't get it way off, nothing more. Quote Link to comment Share on other sites More sharing options...
terribleturner Posted October 24, 2005 Author Share Posted October 24, 2005 Thanks John Quote Link to comment Share on other sites More sharing options...
JohnA Posted October 24, 2005 Share Posted October 24, 2005 In extreme cases, this rule of thumb could lead to over-speccing the injectors by 10-20% (which is no bad thing, just annoying if you realise that you could have kept the stock injectors in place!) For example, if you run lots of water/methanol as I do, you find that the fuelling 'headroom' can be set clearly lower than otherwise. Quote Link to comment Share on other sites More sharing options...
