NF octane booster (race formula) 6ron
MONKEYmark
hi anyone used this octane booster?
just bought some last week for when i got to dragstrip. it says it does up to 6 tanks. 300ml bottle does upto 300 litres
1 to 1.5mls per litre of fuel, was £12 for a bottle
says for full strength this bottle will treat 60litre
bought it off a scooby bloke selling parts at well lane last week.
will use with optimax .
some info here http://www.scoobyscene.co.uk/octane.htm
Before My..... turns up, I have tried it & it works OK. I have run my 100 MON map with it it seemed fine, but only tried this for a short period. I need to do some more tests to see if it is viable to use long term. Won't hurt a standard ECU'd car though. You should be able to run a bit more boost, ( at your own risk obviously) but be sure to listen out for the slightest hint of Det. Stethoscope bolted to the block works well.
Good Luck.
