jackso11 Posted October 21, 2005 Share Posted October 21, 2005 Right....finally picked up my supra from the garage (just bought it) as they were closing tonight. Drove around london abit feeling good! then went on the north circular to driv home so had a chance to open her up a bit......after going about 95kmph (what ever that is in mph) for a couple of minutes these lights cam on. (see pic) so I slowed down, stopped at the first garage and checked the oil and rad..fine. Started her up...no lights...couple of minutes later...lights back on! What do they mean? The car has just had an MOT and service before I picked it up, although one of the headlights is dead so I don't know how it passed the MOT. help please!! Quote Link to comment Share on other sites More sharing options...
Pete Posted October 21, 2005 Share Posted October 21, 2005 ECU error codes Could be anything - there is a way to read them but you'll have to dig around for info here until someone who can remember comes along. Possibly avoid driving until you find out what's up? Probably nothing to worry about though. Quote Link to comment Share on other sites More sharing options...
merckx Posted October 21, 2005 Share Posted October 21, 2005 The one on the left has come on because the one on the right is showing a problem. Could be anything in electrical system or engine. Like Pete say's a diagnostic test might give you the answer. You can do the diagnostic test yourself but I can't find the link. Quote Link to comment Share on other sites More sharing options...
Jake Posted October 21, 2005 Share Posted October 21, 2005 http://www.mkivsupra.net/vbb/showthread.php?t=35920 Quote Link to comment Share on other sites More sharing options...
jackso11 Posted October 21, 2005 Author Share Posted October 21, 2005 the guy in the garage tried to delimit and convert it for me but was using cheap converters so I told him to take it out again (needle was eratic). maybe he hasn't put the wores back together right. Quote Link to comment Share on other sites More sharing options...
tonyhawk Posted October 21, 2005 Share Posted October 21, 2005 When I bought mine, it had a naff gadget on it for reading revs, speed etc., when I ripped it out, I got exactly the same problem, no lights, then a few minutes later, they came on. In my case, it was a wire that I hadn't put back properly on the ECU under the passenger's carpet/footwell. If not, then have a look at: http://www.mkiv.co.nz/ Then go to 'Technical' and then 'Engine diagnostic codes. How to read them' Hope this helps. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted October 21, 2005 Author Share Posted October 21, 2005 right, torch in hand beed outside and got the diagnostic code from the ecu. code 42 Quote Link to comment Share on other sites More sharing options...
tonyhawk Posted October 21, 2005 Share Posted October 21, 2005 Code 42 No 1 Speed Sensor Signal Circuit (Open or short in no. 1 speed sensor circuit) Quote Link to comment Share on other sites More sharing options...
jackso11 Posted October 21, 2005 Author Share Posted October 21, 2005 so thats it! speed sensor reading. when they guy at the garage to the delimiter out he must have not got good connections. Well Matt Harwood is going to sort that out for me when he puts in a Thor delimiter and speedo conversion. At least I know my engine isn't going to blow up. Whe do they put it so close to the oil lights!! it made me think I was going to cease the engine up getting home!!! Quote Link to comment Share on other sites More sharing options...
Ewen Posted October 21, 2005 Share Posted October 21, 2005 Not 42 again.... Quote Link to comment Share on other sites More sharing options...
jackso11 Posted October 21, 2005 Author Share Posted October 21, 2005 I take it to be a common code then... Quote Link to comment Share on other sites More sharing options...
Pete Posted October 21, 2005 Share Posted October 21, 2005 Glad it's nothing serious! Quote Link to comment Share on other sites More sharing options...
jackso11 Posted October 21, 2005 Author Share Posted October 21, 2005 Although my mind won't rest until it is sorted......maybe there is something else wrong too. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted October 21, 2005 Author Share Posted October 21, 2005 anyone know how to reset the ecu? I want to clear the code out so I won't get bogus readings in future Quote Link to comment Share on other sites More sharing options...
Jake Posted October 21, 2005 Share Posted October 21, 2005 anyone know how to reset the ecu? Pull the EFI #1 fuse out for 30 seconds Quote Link to comment Share on other sites More sharing options...
Smudger Posted October 21, 2005 Share Posted October 21, 2005 how much is it for the thor delimiter and speedo conversion and where can i get it done.. ??? Quote Link to comment Share on other sites More sharing options...
Pete Posted October 22, 2005 Share Posted October 22, 2005 Thors website - just over a 100 quid. http://www.thor-racing.co.uk/ Quote Link to comment Share on other sites More sharing options...
jackso11 Posted October 22, 2005 Author Share Posted October 22, 2005 See matt harwood on here. He is fitting mine for me (I am lazy) Quote Link to comment Share on other sites More sharing options...
