SupraHuman Posted October 21, 2005 Share Posted October 21, 2005 Brand new and never fitted.Did not fit my J spec N/A but this will fit UK and USA spec supras.Description below is from Titan motorsports web site. I am asking 200 quid + s/h fees.Cheers. "This water pump is a straight replacement. Don't replace your old and dieing water pump with a stock unit. Whether as a precaution to water pump failure or an upgrade this is a great item. Help improve coolant flow and make power at the same time by eliminating the parasitic loss the stock pump has on the engine. This pump is a straight bolt on and uses the stock or same size belt as the stock water pump. Just wire this pump up to run when the car turns on. Also great for cooling engines down in between rounds as you can wire an additional switch so that it runs when your engine is off to cool it off quickly when racing. This pump is great for any engine and a great new addition. Good to do when the timing belt is being replaced. Features: Hard Anodized Finish Low Amp Draw Frees Over 10 Rear Wheel HP Improves Low Speed Cooling Quick Cool-Down NOTE: This does NOT fit the JDM Supra motor but WILL fit the non-turbo US Spec 2JZ motor. Link to comment Share on other sites More sharing options...
LeeT Posted October 22, 2005 Share Posted October 22, 2005 you might want to reword that. nobody has a US spec non turbo supra in this country:sly: Link to comment Share on other sites More sharing options...
Lucifer Posted October 22, 2005 Share Posted October 22, 2005 Let me do some digging, I way be interested. will let you know monday. Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted October 22, 2005 Share Posted October 22, 2005 Why does it not fit? I thought that all the blocks are technically the same on the outside? Link to comment Share on other sites More sharing options...
SupraHuman Posted October 22, 2005 Author Share Posted October 22, 2005 Why does it not fit? I thought that all the blocks are technically the same on the outside? I was told by Dusty at MVP it would fit UK and USA spec supras,he had sold a few to the UK previous.The pump bracket on the j spec i different to the UK/USA Soop's for some reason....must be a jap thing:confused: Link to comment Share on other sites More sharing options...
SupraHuman Posted October 22, 2005 Author Share Posted October 22, 2005 you might want to reword that. nobody has a US spec non turbo supra in this country:sly: They are not my words mate,i just copied the description from titan motorsports website Link to comment Share on other sites More sharing options...
SupraHuman Posted October 22, 2005 Author Share Posted October 22, 2005 Let me do some digging, I way be interested. will let you know monday.sound..not being funny,but if it ain't sold by monday night then i'll have to send it back to MVP for a refund.I need the dosh for some other bit's Link to comment Share on other sites More sharing options...
