Won't change up? :(
Guest kennyf
My auto box isn't changing up , when I stick it in manu made it does what its meant to do. reverse is also working fine? Is my box dying a death?
I have most of my dash of but can't see that having any bearing it but thought best to mention because knowing my luck it would've been a key bit of information!! :)
Any advice folks?
Have you done a fluid level check. You may need a fluid drain and fill or even a complete flush.
the oil only got changed. last week, friday to be exact but in saying that the car smells very oily now, how do I check the gearbox fluid level? :limp:
I have most of my dash off but can't see that having any bearing it but thought best to mention because knowing my luck it would've been a key bit of information!! :)
Probably something to do with your Speedo or Odometer. The car doesn't know what speed it's doing and what gear to select.
Most likely Speedo since my auto ran ok without the ODO. Just power steering that went to shit.
I'm confused. I have been drinking though :rolleyes:.
Have you sorted it then?
Yeah carlos after the below post ...
...... I pieced my odo back together and the box lived again! Then i removed the AEM and killed the entire car now!!:violin:
I wonder if it is related to you taking the AEM off and reverting back to a stock ECU. Does the stock ecu control the Auto box or is it a seperate ecu?
Im sure the ECU does control the Autobox.
I spoke to Miami GT on this subject when i had a problem with changing up with mine and they said that a ECU re-set may work.
And guess what ..... it did !!! :ok:
Has the problem been sorted yet ?
yeah he's sorted it.. but since then he removed his AEM ecu (god knows how CJ knew about this.. that part of the thread seems to be missing!) and killed the entire car :eek:
I had a couple of threads on the go in various places. lol
Got my box going again but as carlos said I then removed the AEM and due to having 650 injectors in shuts down as soon as it fires up on the OE ECU!! :(
Thanks to jay-450 I should be back on the road mid next week tho. :)
