JDM turbo specs
Terminator
I only have access to a UK spec manual. Obviously the general specs of the UK and JDM are very different. What I don’t know is if the axial play of and the radial play limits of the UK specs turbine shafts are the same. As these figures relate to play in turbo bearings I was wondering if they might be the same. I can’t find these figures for the JDM stock turbos. I don’t think they are the sort of figures that would be normally posted on most sites. I don’t think I have ever seen them quoted any where other than the manual resources on MKIV.com for UK or US cars.
UK specs for turbine shaft play are as follows Maximum Axial play 0.110mm Maximum Radial play 0.162mm
Any has anyone got the JDM specs.
