Blowing gaskets?
Keith C
Just had the car serviced today at my local dealers (who are used to dealing with Supra's), and they say that the turbo-manifold and turbo-downpipe gaskest are blowing a bit.
Does this sound likely? I must admit that there's a bit of a 'rushing air' type noise when then car is on boost, but it's been there since I got the car, and wasn't mentioned at the last service.
Could it just be that the bleed valve is confusing them somewhat?
Try tightening the manifold to head and turbo to manifold joints. The gaskets are fairly heavy duty....... also check for broken studs
I have the manifold to head gaskets and the sealing rings between manifold and turbo available .....
PM if you need them
