FlrSupra Posted September 2, 2010 Share Posted September 2, 2010 I'm really pleased FlrSupra that my post was of use and that your balls will remain intact in Winter! There's really no need to send me any gift, but thanks anyway. Just acknowledging that my post helped you have an easy fix was payment enough for me. Thanks. Steve. Oh it was so warm today Still can`t believe of that quick fix. I`m glad that your glad that I`m glad Quote Link to comment Share on other sites More sharing options...
Guest stanley87 Posted June 5, 2013 Share Posted June 5, 2013 I know three and a half years (exactly) have passed since my post above, but I thought I'd let you know that I did eventually find the problem - about four weeks ago! Hopefully the following may be of some use and potentially save someone a good few hours of wasted time... It did turn out to be the air mixing flap that was causing the problem. When looking from behind the left dash panel (as mentioned above), I could see the actuating arm move ok when the heater temperature knob was turned; what I didn't realise at the time, was that a rod connected to the actuating arm goes down through the heater unit and ends up at point 'A' in the first photo (which is looking up towards the heater unit from the passenger footwell). The actuating arm had come off the air flap lever end as at point 'B' in the second photo (just taken it off again for the photo ) It should be connected as in the third photo at point 'C'. After spending quite some time flushing the system out (which was clean anyway), the fix turned out to be very simple and took no more than a minute or so. Anyway, I've now got a heater that when on maximum it could strip paint. This may seem like a "noob" question, but where can i locate the air mixing flap? Quote Link to comment Share on other sites More sharing options...
SteveC Posted June 5, 2013 Author Share Posted June 5, 2013 This may seem like a "noob" question, but where can i locate the air mixing flap? Have a look at the photos in post 16 of this thread. The actual flap is within the heater unit. The arm that operates the flap can easily be seen from the passenger side (left-hand side) footwell. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 5, 2013 Share Posted June 5, 2013 The usual cause is people having a jump in the passenger seat and some floosie's fishnets getting caught up in the mechanism, allegedly Quote Link to comment Share on other sites More sharing options...
Schtuv Posted July 18, 2013 Share Posted July 18, 2013 SteveC - THANKS :-) My temperature control's been weird for a while, sometimes getting hot and cold, other times doing nothing. Turns out to be that dastardly actuating arm ... which was sometimes working when the passenger well foot mat pushed against it, or the linkage caught on the clip. Quote Link to comment Share on other sites More sharing options...
TBDevelopments Posted November 5, 2013 Share Posted November 5, 2013 great post, was having alook as now the weathers getting cold i've noticed the heaters were a weak point, but checked the rod and mine was the same, disconnected. Heaters are perfect again. This seems very common, mods make it a sticky Tim Quote Link to comment Share on other sites More sharing options...
LordNelson Posted January 16, 2024 Share Posted January 16, 2024 oh my god...may have stumbled on a beauty here....im going to try this later Quote Link to comment Share on other sites More sharing options...
Guigsy Posted January 17, 2024 Share Posted January 17, 2024 same. my heating hasnt been working since i replacced the core. i wonder if we didnt reconnect or nudged something so now this isnt moving. Quote Link to comment Share on other sites More sharing options...
