nismo_lp Posted October 19, 2005 Share Posted October 19, 2005 ...should i expect to pay for a full decat (already had a rear decat) and a restrictor ring ... all fitted? Is it worth getting a boost controller? Can you only reduce the boost with the controller? Oh and lastly... if i provide the gauge how much should i expect the fitting to cost? Would it be the same for dash and pod gauges? Thanks for any info. Link to comment Share on other sites More sharing options...
monkey3 Posted October 19, 2005 Share Posted October 19, 2005 People normally say that when you decat and put in the restrictor ring you should end up with about the same amount of boost. Unfortunately the boost controller cannot decrease boost, hence the restrictor ring, it can only up it. As far as I am aware the boost controller works in a similar fashion to a bleed valve, although a lot more technically, in that it effectively fools the ecu into thinking that it has not yet made full boost and so it needs to keep boosting before it opens the wastegate. Although I could be wrong. As far as prices go, not a clue. Link to comment Share on other sites More sharing options...
monkey3 Posted October 19, 2005 Share Posted October 19, 2005 see http://www.mkivsupra.net/vbb/showthread.php?t=48158 about the boost controller stuff. Link to comment Share on other sites More sharing options...
nismo_lp Posted October 19, 2005 Author Share Posted October 19, 2005 Thanks mate ... Does anybody have any idea of how much i should be paying out for the job? Link to comment Share on other sites More sharing options...
nismo_lp Posted October 20, 2005 Author Share Posted October 20, 2005 Anyone??? Link to comment Share on other sites More sharing options...
merckx Posted October 20, 2005 Share Posted October 20, 2005 Front decat pipe £150 TRL FCD £82 Spark plugs £12-£60 Walbro fuel pump is a good idea £80 Plus maybe 4-5 hours labour , depends on who does it. Best to contact Chris Wilson or one of the traders on here and ask them, they'll do the best job. Link to comment Share on other sites More sharing options...
