cam belt change
Need4Speed
Not done it myself, but from reading other posts watch the radiator - may have to take it off, don't use heat just a BIG wrench (not usre if there is a special tool available) in addition the the normal cambelt timing issues etc.
Belt is 13568-49036
(wait for someone better....)
Steve,
YES, there IS a special Toyota Crank-Pulley-Tool ! !
and TOYOTAS DON'T USE IT ! ! ! !
They use a VERY large Chain Wrench (ie. an enormous 'filter' wrench).
AND, you're dead right, NO HEAT - or you may bugger the crank
damper ! !
