gregsupra4 Posted October 19, 2005 Share Posted October 19, 2005 Need a set of aftermarket adjustible cam gears for my 1995 J2ZGTE Supra. Thanks. Greg. Link to comment Share on other sites More sharing options...
Alex Posted October 19, 2005 Share Posted October 19, 2005 FWIW - Nobody NEEDS them...you can't really gain anything worth the effort. Stock settings are always best...unless you've put something a bit bonkers in. Link to comment Share on other sites More sharing options...
gregsupra4 Posted October 19, 2005 Author Share Posted October 19, 2005 Thanks for that Alex, but now that the winter is upon us the old supe is having another make over. She will be sporting 2 x Super T70 turbos, 1000cc injectors, veilside intake manifold, new pistons,rods,crank plus new AEM and lots of other goodies. Just thought that I might see if anybody had a set for sale rather than go through ebay. See Ya. Greg Link to comment Share on other sites More sharing options...
CJ Posted October 19, 2005 Share Posted October 19, 2005 I had HKS adjustable and they had worn so badly they stripped the teeth on my newly fitted cam belt. I have heard many people say the same (especially in the USA) and have reverted to stock gears. I also remember talking to CW and he asked a pertinent question. He wondered how often I had adjusted them from the stock position? The answer? Never. Link to comment Share on other sites More sharing options...
gregsupra4 Posted October 19, 2005 Author Share Posted October 19, 2005 Hi CJ, Ok if I continue to use the stock cam gears how can I adjust the duration of both the inlet and exhaust without changing the cams themselves ?????? Link to comment Share on other sites More sharing options...
RobSheffield Posted October 19, 2005 Share Posted October 19, 2005 She will be sporting 2 x Super T70 turbos, 1000cc injectors, veilside intake manifold, new pistons,rods,crank plus new AEM and lots of other goodies. :eek: is that like a VERY BIG TWIN??? lol Link to comment Share on other sites More sharing options...
gregsupra4 Posted October 19, 2005 Author Share Posted October 19, 2005 :eek: is that like a VERY BIG TWIN??? lol How clever of you to notice that. Link to comment Share on other sites More sharing options...
Alex Posted October 19, 2005 Share Posted October 19, 2005 They arn't T70's as in 70mm Compressors. Like a ITS T-71 is a 71mm Compressor. Different manufacturers use different naming convensions. However they are still enough for over 500Hp each. Link to comment Share on other sites More sharing options...
RobSheffield Posted October 19, 2005 Share Posted October 19, 2005 How clever of you to notice that. yeah, thanks for noticing, dont think you quite grasp what i meant, but since i cba to point it out, i will leave it there Link to comment Share on other sites More sharing options...
Alex Posted October 19, 2005 Share Posted October 19, 2005 Old style HKS cam gears are best avoided... You need to find Steel wheels with 5-bolt designs...like the JUN ones...but they may be discontinued. Link to comment Share on other sites More sharing options...
garethr Posted October 19, 2005 Share Posted October 19, 2005 Just a thought .... A member of the Australian Soarer Club who had problems with the HKS cam gears (snapped belt) had some made using the Toyota gears. It worked out at 185 AUD + 45 AUD deposit per gear (about 80 / 20 of your English pounds). How much would it be over here? http://soarercentral.com/sc-forum/messages/292/13004.html . Link to comment Share on other sites More sharing options...
Alex Posted October 19, 2005 Share Posted October 19, 2005 Just looked at Gareth's link...the dyno looks good after 4000rpm with the inlet cam...but look at what it does to the low down part of the graph. The exhuast timing was overall benefitial without too much compromise. Possibly less agressive changes to the inlet cam will further aide it. Link to comment Share on other sites More sharing options...
CJ Posted October 19, 2005 Share Posted October 19, 2005 Hi CJ, Ok if I continue to use the stock cam gears how can I adjust the duration of both the inlet and exhaust without changing the cams themselves ?????? I was lucky (if spending more money can be classed as lucky) in that I used uprated cams and hence the reason behind not needing to use adjustable gears. I went with 256 inlet and 264 exhaust. Link to comment Share on other sites More sharing options...
garethr Posted October 19, 2005 Share Posted October 19, 2005 Hi CJ, Ok if I continue to use the stock cam gears how can I adjust the duration of both the inlet and exhaust without changing the cams themselves ?????? Even with the adjustable gears, you can't change the cam duration. You can change the lobe centres and the overlap. Link to comment Share on other sites More sharing options...
Lucifer Posted October 19, 2005 Share Posted October 19, 2005 I think the comments came from the OLD HKS gears, the new style no one has had an issue with yet! Link to comment Share on other sites More sharing options...
CJ Posted October 19, 2005 Share Posted October 19, 2005 I think the comments came from the OLD HKS gears, the new style no one has had an issue with yet! How old are the "old" style ones? I had mine fitted about 14 months ago. Link to comment Share on other sites More sharing options...
Lucifer Posted October 19, 2005 Share Posted October 19, 2005 Not 100% sure, but they have a new material for the outer ring... If anyone can find the article post it up here. Link to comment Share on other sites More sharing options...
Alex Posted October 19, 2005 Share Posted October 19, 2005 The new ones are steel the old are Ali - should be able to tell which type they are Link to comment Share on other sites More sharing options...
CJ Posted October 19, 2005 Share Posted October 19, 2005 The new ones are steel the old are Ali - should be able to tell which type they are Not if you are buying them from America or Japan. Link to comment Share on other sites More sharing options...
gregsupra4 Posted October 19, 2005 Author Share Posted October 19, 2005 OK GUY'S Thank you for all your suggestions BUT ALL I WANT TO KNOW IS "DOES ANYBODY HAVE A SET OF AFTERMARKET CAM GEARS FOR SALE" IF YOU DO PLEASE CONTACT ME. THANK YOU. Link to comment Share on other sites More sharing options...
Guest Terry S Posted October 19, 2005 Share Posted October 19, 2005 The new ones are steel the old are Ali - should be able to tell which type they are You sure they are, and not just ali with a better coating? Link to comment Share on other sites More sharing options...
Alex Posted October 19, 2005 Share Posted October 19, 2005 That's what I read...but what I read could have been wrong. Link to comment Share on other sites More sharing options...
Guest Terry S Posted October 19, 2005 Share Posted October 19, 2005 That's what I read...but what I read could have been wrong. From HKS USA site HKS Cam Gears are made completely of anodized Duralumin with nickle plated gear teeth Link to comment Share on other sites More sharing options...
Sharpie Posted October 19, 2005 Share Posted October 19, 2005 should be able to tell which type they are Yep, the old ones have green/blue teeth, if that's the right term and the new ones do not. Link to comment Share on other sites More sharing options...
Digsy Posted October 19, 2005 Share Posted October 19, 2005 Hi CJ, Ok if I continue to use the stock cam gears how can I adjust the duration of both the inlet and exhaust without changing the cams themselves ?????? You can't change duration with adjustable gears anyway. You can only change the timing. To change duration you need new cams. Link to comment Share on other sites More sharing options...
