Supra he-t with error codes ☹️
phil.g.
Hi,
I have a ge-t that has some error codes and desperately need help to sort them please, the errors are codes are:-
14
21
31
47
im running a single turbo, an after market alloy inlet, bigger throttle body with reversed tps, plug and play coil on packs through a gte Ecu and the blue g-reddy performance piggyback Ecu, any help would be greatly appreciated,
thanks very much,
phil.
  • 4 weeks later...
14 is ignition circuit, if I remember you used to get that through boost cut. What MAP sensor are you using?
21 is O2 sensor
31 is MAP sensor
47 is TPS related
They may be due to a failing stock ECU, you haven't said what the spec of the car is. Honestly, best advice is to get rid of that emanage, its so old now and spend money on decent management, Link stuff is cheap and well supported now.
Edited by Swampy442 (see edit history)
