Big Supes Posted February 9 Share Posted February 9 (edited) I'm currently selling my original UK-Spec Supra 2JZ as I have acquired a forged engine for future power goals. The engine has done 118k miles and has never missed an oil change. When I purchased the car 11 years ago, it had FSH and I've always stayed on top of servicing since. The car was originally auto and was changed to BPU auto around 10 years ago. Around 2 years ago it was changed to 6sp single turbo running 600whp. It has relatively new valve stem oil seals, water pump and oil filter house seal. The engine still has the factory seal as it's never been opened. It doesn't smoke or have any suspect taps or knocking noises. SRD fitted 264 cams which will come with the engine. It was also mapped by @Mike2JZ at SRD for the single turbo set up. I can provide videos of the engine running and also power runs on the dyno which show no smoke when under load. Can throw in the UK inlet and TB if needed. Engine is located in Dorset. 5k Edited February 17 by Big Supes (see edit history) Link to comment Share on other sites More sharing options...
Big Supes Posted February 17 Author Share Posted February 17 Pictures added. Link to comment Share on other sites More sharing options...
