Is there a list of all the plugs found on the MK4?
SUPRA4EVA
90980-11182 is the OE
5 pin connector but not all pins used on some cars ( depends if folding or not )
I use a molex connector - you can get a box of connectors and pins - 2/4/5/6/8/10 pins male and female with about 200 pins and sockets for about £15 , so plenty of spares for future use - pins are also fitted with a pair of pliers ,no crimp tools needed -I add the smallest tad of solder . These also fit the ganador pins connector
  • 2 weeks later...
Hmm didn't see this post...molex as in the old skool pc fan plug?
Well I got the 5 pin male plug with my retract mirrors and I assume my UK mirror/loom will also be 5 pin plugs with 3 wires...or I can re pin it if it's a 9 pin plug, which I doubt.
So I just need the 82998-12650 female repair wire type 1.3.
Trouble is they cost like £50 for 1 strand and i need 4 for the retract motors!! F that!
Is there an alternative or aftermarket number for those female terminals?
There is also a hole plug 90980–09414 but it's discontinued.
https://www.switchelectronics.co.uk/products/5-way-straight-pcb-crimp-housing-2-54mm?currency=GBP&variant=45606348554549&utm_source=google&utm_medium=cpc&utm_campaign=Google Shopping&stkn=bbf1d20e1ed7&gad_source=1&gbraid=0AAAAAqEgT0Abwtc4Pn-nx2eEQMtjf6S9v&gclid=EAIaIQobChMIutGUn6bIiwMVK5JQBh3O5ydpEAQYBSABEgJRfPD_BwE
the mirror has a 5 pin connector - male pins ,by convention all connectors that have power are female , and all connectors that are powered are male …this is to prevent short circuits by 2 male pins touching .the stock connectors have slots - orientation to stop cross connections to a wrong plug . The pin spacing is 2.54 mm between pins . The molex has the correct spacing but no orientation - it should just push in . I am not sure what your issue is - a damaged connector ? Pins are also available a few hundred female pins for maybe a pound , these can be fitted with pliers /side cutters so no crimping tool needed …correct tool is over £300 . You can also just replace both connectors - extend the looms to for ease of fitment . I don’t know what your issue is
the ganador mirrors dont come with OEM connector - they have a circuit board with the 5 pins on top - all open ,but they do connect to OEM door loom connector - much like molex connector -
