Japspeed alloy radiator
bluecoupe46
For sale is my old Japspeed alloy radiator.
This radiator has been in storage for the last few years and prior to that was installed in my car. Although it was installed and had coolant in it I never actually started the car with it in so it’s never technically been used.
The lower mounting brackets don’t work great with the oem rubber mounts as the radiator sits quite high, so you may need to shave down the oem mounts a little. That said my bonnet is out of adjustment since the bodyshop took it off for the respray, so maybe it’s just my car!
£50 takes it as it’s got some bent fins and I just want it out of my way.
P.s. Collection only from Pershore, Worcestershire. However I travel for work so depending upon location I may be able to deliver or meet you somewhere if near one of my routes.
£50
