SuperSupra Posted October 18, 2005 Share Posted October 18, 2005 Anyone else seen this ad on Ebay? http://cgi.ebay.co.uk/TOYOTA-SUPRA-MA70-GA70-JZA80-2JZ-GTE-7M-GTE-2JZ-GE-VVTi_W0QQitemZ4581390016QQcategoryZ10428QQrdZ1QQcmdZViewItem Anyone purchased one or know anyone who has? Sounds like a bit of a gimmick to me! Link to comment Share on other sites More sharing options...
Ian C Posted October 18, 2005 Share Posted October 18, 2005 I've got the RR one It's brill and I haven't even fitted it in the Supra yet, just my housemate's BMW. If it's not the RR you don't get any of the datalogging so IMO it's not even worth considering. -Ian Link to comment Share on other sites More sharing options...
JohnA Posted October 18, 2005 Share Posted October 18, 2005 It's an old version, hence the cut-down price. Still, it's better than "seat of pants" figures. Link to comment Share on other sites More sharing options...
GeordieSteve Posted October 18, 2005 Share Posted October 18, 2005 Pah! I sold them for less than that Good bits of kit tho Link to comment Share on other sites More sharing options...
SuperSupra Posted October 18, 2005 Author Share Posted October 18, 2005 So it is actually accurate then? Can measure the bhp your motor's running, and 0-60 times etc? Link to comment Share on other sites More sharing options...
JohnA Posted October 18, 2005 Share Posted October 18, 2005 If you provide it with vehicle weight and some aerodynamic/rolling resistance approximations it should be able to give you bhp figures, IF the measurements have been done correctly on a flat straight. My accelerometer is more expensive than this one, but it can datalog as well. For measuring 0-60 and 1/4mile times this one doesn't look too bad, saves you going to the Pod until you've perfected your launches. Link to comment Share on other sites More sharing options...
imi Posted October 18, 2005 Share Posted October 18, 2005 you should go for the competition version instead. thats well worth it. Link to comment Share on other sites More sharing options...
JohnA Posted October 19, 2005 Share Posted October 19, 2005 I've had this one for quite some time, and it works well Link to comment Share on other sites More sharing options...
Ian C Posted October 19, 2005 Share Posted October 19, 2005 So it is actually accurate then? Can measure the bhp your motor's running, and 0-60 times etc? It measures "horsepower used to accelerate the car". This is the engine power minus drivetrain losses, tyre frictional losses, and most importantly - overcoming aerodynamic drag losses. That last bit means it'll always read under your dyno figures because that doesn't take into account any wind resistance. It is actually quite accurate. The bimmer got 0.89 to 0.93g on a roundabout with the stability control system having an embolism. It pegged a 9s 0-60 as well which is within book figures. 1g braking force. Absolutely wrecked weekly shopping. -Ian Link to comment Share on other sites More sharing options...
JohnA Posted October 19, 2005 Share Posted October 19, 2005 Mine has a good algorithm that calculates drivetrain, rolling and aerodynamic losses. It's not perfect but it's a good approximation up until 120mph at least. It asks you to do two sets of rolling timings on a FLAT straight road, one say at 20->10mph and another 60->50mph (can't remember exactly) It calculates friction and aero parameters out of that, and uses them in subsequent 'power' calculations. They came pretty damn close to 'hub' dyno figures I got on the same setup (with correction factor=1) Link to comment Share on other sites More sharing options...
wez_p Posted October 19, 2005 Share Posted October 19, 2005 i've got one of these (not from this seller though) and think for the money it's a great little gadget it seems to be pretty accurate & more importantly consistent - so i got it to measure improvements after mods the bhp did seem low when i tried that one, but i'm nto sure whether i'd worked out the weight correctly plus it does as previously mentioned measure more realistically than a rolling road for that money, you can't really go wrong, in my opinion (unless it's broke when it arrives!) Link to comment Share on other sites More sharing options...
Mike Posted October 19, 2005 Share Posted October 19, 2005 I think this has been covered before... once or twice.. My cynicism and eventual understanding of how such gadgets work is documented here… Link to comment Share on other sites More sharing options...
Ian C Posted October 19, 2005 Share Posted October 19, 2005 Not sure if anyone mentioned this to you before but the RR version at least has, in the car setup area, a degree setting where you put in the degrees your car tilts when under hard acceleration/braking/cornering. So as long as it's on the flat you can compensate for squat, dive, and body roll. It even has detailed instructions on using a pukka drag strip to help calibrate this, by comparing trap speeds It is also affected by the angle it's at but it self-calibrates around that on the first drag run you do. And the suction cup and mount are extremely good for holding the thing still. Overall I'm impressed by it apart from the slightly plasticky casing. Don't drop it -Ian Link to comment Share on other sites More sharing options...
ivan Posted October 19, 2005 Share Posted October 19, 2005 I've had one of these for nearly a year now. And not got round to using it yet... Link to comment Share on other sites More sharing options...
Sharpie Posted October 19, 2005 Share Posted October 19, 2005 It has a soop on the box, must be good Why it needs the air-intake headlight replacement on BOTH sides is..... ? Link to comment Share on other sites More sharing options...
