mark newman Posted December 15, 2024 Share Posted December 15, 2024 Hi does anyone know where you can buy a rebuild kit for a large differential B04B Auto in the uk , as mine is whining, so hopefully it's just bearings. Quote Link to comment Share on other sites More sharing options...
jagman Posted December 16, 2024 Share Posted December 16, 2024 https://www.grannasracing.com/products/toyota-oem-220mm-big-6-speed-rear-end-lsd-differential-rebuild-kit?_pos=1&_sid=9fd24ca9d&_ss=r They all look to be toyota parts so maybe via dealer ? Or timken suppliers Quote Link to comment Share on other sites More sharing options...
AC93 Posted December 17, 2024 Share Posted December 17, 2024 Have you tried Paul Cheshire? Quote Link to comment Share on other sites More sharing options...
jagman Posted December 18, 2024 Share Posted December 18, 2024 Amayama , show the breakdown of the 220 diff with part numbers - not U.K. but the bearings are all under $28 each ,seals also cheap and even retainers and all new bolts are cheap ,even with delivery and duty and a delay for delivery - much cheaper than the US . U.K. bearing prices have rocketed and even then they might be on back order ,multiples of the amayama prices !! - looks like the 220 diff is the US export manual trans diff - for searching purposes on amayama . Quote Link to comment Share on other sites More sharing options...
mark newman Posted January 11 Author Share Posted January 11 Thanks , but is there a good garage that are formiler rebuilding supra differentials. Quote Link to comment Share on other sites More sharing options...
Big Supes Posted January 11 Share Posted January 11 52 minutes ago, mark newman said: Thanks , but is there a good garage that are formiler rebuilding supra differentials. As mentioned above. Give Paul Cheshire a call. Quote Link to comment Share on other sites More sharing options...
mark newman Posted January 11 Author Share Posted January 11 Thanks just sent for quote Quote Link to comment Share on other sites More sharing options...
