HunterJ Posted October 18, 2005 Share Posted October 18, 2005 Hi Folks, Firstly, I've checked out the other tapping noises mentioned on the board, but none seem to match (if I've missed a post, please accept my appologies, but please point me in its direction ). I was going through the KFC drive through yesterday and as I was moving, I had the window down, I heard a strange tapping sound coming from around my drivers side rear quarter. It sounds very metallicy (kinda like I was dragging a chain). It seems to be related to speed. It can be heard quite clearly when driving slowly (pulling away from junctions etc) as long as the window is down. Both rear wheel bearings have been replaced recently, and everything seems tight on the wheels. Any ideas? Its a 93 Jap spec TT with around 130km on the clock. Cheers Jamie Link to comment Share on other sites More sharing options...
npotts Posted October 18, 2005 Share Posted October 18, 2005 Hi Jamie Have you checked the rear brake pads? When low, a metal strip scraps on the disc to remind you to replace the pads - this is the first thing I would check. Is the disc rubbing on the hub? Might be worth taking the wheel off and disc and seeing if there are any 'worn' marks on the hub or disc pointing to some chaffing of some sort... Im sure someone else will offer some other advice. Im far from technical on these issues.... Nick Link to comment Share on other sites More sharing options...
supRo Posted October 18, 2005 Share Posted October 18, 2005 Check Handbrake shoes/spring..... I've had similar sympthoms. Link to comment Share on other sites More sharing options...
Paul Posted October 18, 2005 Share Posted October 18, 2005 Check Handbrake shoes/spring..... I've had similar sympthoms. I had problems with the retaining clip on the shoes hitting the back of the drum. Paul Link to comment Share on other sites More sharing options...
HunterJ Posted October 18, 2005 Author Share Posted October 18, 2005 Great guys, thanks for the pointers. Its in for an MOT on Thursday I'll get the garage to have a look - the nuts are on too tight, I couldn't get them off by hand! Cheers Jamie Link to comment Share on other sites More sharing options...
TLicense Posted October 18, 2005 Share Posted October 18, 2005 Errr were you dragging a chain? No, oh, OK. Well does it go away when you put your foot on the brake or if you apply the handbrake when travelling slowly? Link to comment Share on other sites More sharing options...
HunterJ Posted October 19, 2005 Author Share Posted October 19, 2005 Spot on with the handbrake suggestion - whilst driving (very slowly) I gently pulled the handbrake - the noise dissappeared, and it hasn't come back (yet;)) Jamie Link to comment Share on other sites More sharing options...
