Supraman1511 Posted October 23, 2024 Share Posted October 23, 2024 (edited) Does anyone know if the front section of the NA Auto prop is the same as the TT Auto prop? The ZF8 kit is designed for the TT Auto prop which seems impossible to find (and I assume a big case diff) I am wondering if the only difference between the 2 auto props is the length (to reach the different diff case sizes) and the size of flange that connects to the donut? small flange on the NA small diff and big flange on the TT big diff So in theory the ZF8 coupler could also bolt straight on to the NA prop with small diff? Of course the 4.0xx diff ratio of the NA Auto would be terrible for the ZF8 BUT I have picked up a 2001 LS430 diff which is 3.2xx just like the 6spd, this is a small case diff with big flange SO... Can I switch the diff flange of the LS diff to use the small flange from my NA A01a diff and be good to go? (I'm also building a GE VVTi and boosting it to around 600bhp to go along with this) Edited October 23, 2024 by Supraman1511 (see edit history) Quote Link to comment Share on other sites More sharing options...
AC93 Posted October 23, 2024 Share Posted October 23, 2024 Annoying the LS diff flange has a different PCD to the Supra so you can't just swap the flange because the prop won't bolt up. I found out the hard way So you need to take the 3.2 gear ring out the LS diff and put it in the Supra casing Quote Link to comment Share on other sites More sharing options...
Supraman1511 Posted October 23, 2024 Author Share Posted October 23, 2024 Thanks I thought you could just switch the diff flange? So if I took the A01a diff flange "small" PCD and put it in the LS diff, then it would match the prop? Either way you've given me an option thanks if I can use the 3.2 gear ring with the A01a diff and NA Auto prop with the ZF8 coupler, then that's perfect Quote Link to comment Share on other sites More sharing options...
AC93 Posted October 24, 2024 Share Posted October 24, 2024 Ah yes you could do that, I assume you're adding a LSD core as well to the Lexus diff? 1 Quote Link to comment Share on other sites More sharing options...
bluesonic94 Posted October 25, 2024 Share Posted October 25, 2024 No 1 Quote Link to comment Share on other sites More sharing options...
Supraman1511 Posted October 25, 2024 Author Share Posted October 25, 2024 Yeah probably OS Giken or Cusco 1.5 if anyone has any advice on that? Quote Link to comment Share on other sites More sharing options...
AC93 Posted October 30, 2024 Share Posted October 30, 2024 On 10/25/2024 at 12:30 PM, Supraman1511 said: Yeah probably OS Giken or Cusco 1.5 if anyone has any advice on that? OS Giken Quote Link to comment Share on other sites More sharing options...
