phil.g. Posted October 4 Share Posted October 4 (edited) Hi everyone, i had a problem a few years ago with a loom I cut through, long story short I thought I put it all back together correctly but my indicators are not working correctly, I put the ignition on and the left front comes on constantly, I’ve looked on the wiring diagrams and need to know where the 2 grey blocks in the pic are and where they are located, I can then take a wire from them to the bulb and hopefully that will solve the issue, any help would be great, thanks in advance, phil, Edited October 4 by phil.g. (see edit history) Quote Link to comment Share on other sites More sharing options...
mc92 Posted October 4 Share Posted October 4 (edited) My wiring diagram says that those connections are in the driver's footwell fuse box. Edited October 4 by mc92 (see edit history) Quote Link to comment Share on other sites More sharing options...
phil.g. Posted October 4 Author Share Posted October 4 Thanks for the reply, do you think it’s a relay on the fuse board? Quote Link to comment Share on other sites More sharing options...
mc92 Posted October 5 Share Posted October 5 Depends where you damaged the loom I guess. On the previous diagram it looks like the left indicator comes out of pin 7 on connector 1A so that might be a good place to start if you're planning to run a new wire. If it was my car I'd try to repair it at the break if possible to make it neater. Here is a link to the wiring document I like. https://drive.google.com/file/d/12WaKCt4xpm3_Ka6JbKqPFyQ2e4P0Th12/view Quote Link to comment Share on other sites More sharing options...
phil.g. Posted October 5 Author Share Posted October 5 Oh wow thanks very much for the link, I should be able to sort it now, a massive thanks again to you mc92 1 Quote Link to comment Share on other sites More sharing options...
phil.g. Posted October 6 Author Share Posted October 6 Well after some further investigation into plug 1A I find out that it was plugged into the hole above in the 1F socket and over 1 row, I have no clue when that was miss placed, all fixed now and not a single repair to a wire at all, thanks again mc92 Quote Link to comment Share on other sites More sharing options...
