phil.g. Posted October 4, 2024 Share Posted October 4, 2024 (edited) Hi everyone, i had a problem a few years ago with a loom I cut through, long story short I thought I put it all back together correctly but my indicators are not working correctly, I put the ignition on and the left front comes on constantly, I’ve looked on the wiring diagrams and need to know where the 2 grey blocks in the pic are and where they are located, I can then take a wire from them to the bulb and hopefully that will solve the issue, any help would be great, thanks in advance, phil, Edited October 4, 2024 by phil.g. (see edit history) Quote Link to comment Share on other sites More sharing options...
mc92 Posted October 4, 2024 Share Posted October 4, 2024 (edited) My wiring diagram says that those connections are in the driver's footwell fuse box. Edited October 4, 2024 by mc92 (see edit history) Quote Link to comment Share on other sites More sharing options...
phil.g. Posted October 4, 2024 Author Share Posted October 4, 2024 Thanks for the reply, do you think it’s a relay on the fuse board? Quote Link to comment Share on other sites More sharing options...
mc92 Posted October 5, 2024 Share Posted October 5, 2024 Depends where you damaged the loom I guess. On the previous diagram it looks like the left indicator comes out of pin 7 on connector 1A so that might be a good place to start if you're planning to run a new wire. If it was my car I'd try to repair it at the break if possible to make it neater. Here is a link to the wiring document I like. https://drive.google.com/file/d/12WaKCt4xpm3_Ka6JbKqPFyQ2e4P0Th12/view Quote Link to comment Share on other sites More sharing options...
phil.g. Posted October 5, 2024 Author Share Posted October 5, 2024 Oh wow thanks very much for the link, I should be able to sort it now, a massive thanks again to you mc92 1 Quote Link to comment Share on other sites More sharing options...
phil.g. Posted October 6, 2024 Author Share Posted October 6, 2024 Well after some further investigation into plug 1A I find out that it was plugged into the hole above in the 1F socket and over 1 row, I have no clue when that was miss placed, all fixed now and not a single repair to a wire at all, thanks again mc92 Quote Link to comment Share on other sites More sharing options...
