Which pulley is this in the picture? JZ-GE Engine
Degsy
do you know how it normally works?   The outer part always spins (without the belt its very free running) but the inner bit only spins when the aircon is on and even then it cycles between spinning and not spinning. If you reached in and grabbed the inner cylinder/lip you should be able to rotate it a little and the belt won't move, it's independent to the outer ring until it's electro magnetically brought together.
  • Like 1
