Degsy Posted September 4, 2024 Share Posted September 4, 2024 The pulley on the bottom right on this pic has started to stick and not rotate. Can anyone identify it and are they available to purchase? Quote Link to comment Share on other sites More sharing options...
mc92 Posted September 4, 2024 Share Posted September 4, 2024 The small one? I believe it's the AC compressor. Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted September 4, 2024 Share Posted September 4, 2024 That small one below power steering pump is your Air Con compressor, i know can get aftermarket pulleys unsure about stock replacement. Quote Link to comment Share on other sites More sharing options...
Degsy Posted September 5, 2024 Author Share Posted September 5, 2024 Cheers folks many thanks. Quote Link to comment Share on other sites More sharing options...
Scooter Posted September 6, 2024 Share Posted September 6, 2024 do you know how it normally works? The outer part always spins (without the belt its very free running) but the inner bit only spins when the aircon is on and even then it cycles between spinning and not spinning. If you reached in and grabbed the inner cylinder/lip you should be able to rotate it a little and the belt won't move, it's independent to the outer ring until it's electro magnetically brought together. 1 Quote Link to comment Share on other sites More sharing options...
