SOLD - Aftermarket guages. Boost, afr, oil temp, fuel pressure/temp
Guigsy
Check the replies for other guages.
Will give it a week or 2 here then will throw this up on ebay
Blitz racing meter SD boost guage. Came out of my car. I think all the cables are there, includes dash holder, instructions and brackets that I never used.
Not sure why some of these pics came through upside down...
£130
Edited by Guigsy (see edit history)
SPA, dual fuel pressure/oil temp guage. Screen is blue backlit. Was in my car. I believe all the cables are there but some were cut to remove. Includes a sensor. But I'm not sure what the sensor is for. £160
20240826_144634.thumb.jpg.8b32172ce2e422929ff8aff6a6b4ce1d.jpg20240826_144626.jpg.391b90c47f15edc34b87db7fde7d1f70.jpg
AEM afr ratio guage.
Removed from my car, I believe the cables are all there but were cut to remove. No sensor. Come with an extra silver bezel and a black face (although that's labeled Lambda)
£100
20240826_145146.thumb.jpg.ce80d5b11a2c46a542b01fff57183fd8.jpg20240826_145124.thumb.jpg.18debabe4c7cafb20ca0790abbeca3b7.jpg
Posted (edited)
Defi link series oil temp guage.
Shadow face so it's blank untill turned on. Not sure on the colour when lit. I assume white as when I had defi gauges they were white. Includes sensor, manual etc. you need the controll box for this to plug Into for it to work.
£60
  • Guigsy changed the title to SOLD - Aftermarket guages. Boost, afr, oil temp, fuel pressure/temp
