R154 and nearly all the conversion parts
steve spedd
Hi!
No photos as it’s at the unit but have the following available for a R154 conversion with the following:
• R154 Gearbox (was in working order when removed)
• Used 2JZ Bell Housing (OEM Toyota), it is missing the dust cover to the access hole, but these can be bought new still.
• 1JZ Flywheel (I think! required to bolt the clutch and R154 to the 2JZ)
• 3+ Spec Clutch (used for about 500 miles)
• Mk3 Supra Propshaft (The front half of this bolts to the original rear half of the Mk4 propshaft)
• OEM Toyota Gearbox Mount with brand new Drift Motion mounting kit (required to achieve the correct angle on the propshaft)
• Lengthened shifter housing to suit the Mk4 Supra transmission tunnel
• New Cube Speed shifter bushings
• OEM Toyota shift lever
• Clutch Master Cylinder
• Clutch Pedal Assembly
• Manual Brake Pedal Assembly
• Hard line from the clutch master cylinder to the slave cylinder
Parts needed:
• Flywheel bolts
•Slave Cylinder
• Gearbox oil
as Said I have a flywheel but need to check if it’s W58 or 1JZ
after £2,500 for the lot…
located chesterfield, Derbyshire
thanks
steve
  • Like 2
  • 3 months later...
  • 2 weeks later...
  • 2 months later...
  • 1 month later...
