Remove rev limiter on Renault Trafic
Steve
Anyone got any ideas on how to, if possible remove the rev limiter/governor on a new Renault Trafic 1.9DCI.
Its a pain in the arse.
Looked on the net, the only thing i can find is a plug in unit which increases power but does not remove the poxy limiter.
its fully mechanical, removing will void warranty and is of no use, as power drops off quickly after
i work for renault, and when we had the launch, the Vans didnt have governers at that speed, they were awful - but with it i love them, i drive all the Trafics and Masters
the Van has 6 gears, use them, when you get to 3800 rpm, change up!
i embarrass car drivers when im out in it!
  • 4 years later...
Guest zzrkid
Hi rob you seem to be well versed on the trafic, i wonder if you could help me.
I have an 08 trafic 115 dci been in an accident and now won;t start air bag deployed.
The impact took out the n/s light and fuse/relay box, i have 5 wires which look as if thay need a ralay on but i can't find out what, the wire colours are black,red,yellow,purple and white local dealer no help at all, can you suggest anything.
On the main topic Mr Renault put a rev limiter there for a purpose i would have thought you don'.t get mant diesels revving more than 4k:innocent:
