ScottPawsey Posted May 16, 2003 Share Posted May 16, 2003 I'm fitting a activer spoiler and have to remove the front bumper I can see three bolts at the top but thats about it can anyone help. These bloody supra's are so well built. Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted May 16, 2003 Share Posted May 16, 2003 Need to remove the headlights and two bolts either side. You also need to remove the plastic strips inside the opening in the front and should be able to pull forwards then. Quote Link to comment Share on other sites More sharing options...
toyotasuprauk Posted May 16, 2003 Share Posted May 16, 2003 This may make it look harder than it really is but could be worth a look? Adrian Quote Link to comment Share on other sites More sharing options...
ScottPawsey Posted May 16, 2003 Author Share Posted May 16, 2003 Surprise Surprise you have to remove the head lights, cheers Martin I'll give that a go. Scott Quote Link to comment Share on other sites More sharing options...
ScottPawsey Posted May 16, 2003 Author Share Posted May 16, 2003 Pictures are always good It looks very detailed cheers Adrian. Quote Link to comment Share on other sites More sharing options...
Supra_Al Posted May 16, 2003 Share Posted May 16, 2003 Scott, Hi.........are you actually going to fit the front active spoiler to work? Or are you fitting it for looks? I see you have an NA like myself, i brought an active spoiler,but only used the rubber lip, as the rest of the ali frame etc, add far too much weight imo.Very easy to fit the lip only for looks,with hardly any extra weight.See pic below, regards Al. Quote Link to comment Share on other sites More sharing options...
ScottPawsey Posted May 16, 2003 Author Share Posted May 16, 2003 I would but i want to be able to move it I'm thinking about some eibach springs. With all the speed humps it would be nice to raise it if need be but i'll keep that in mind Quote Link to comment Share on other sites More sharing options...
