Removing the front bumper
ScottPawsey
Guest Martin F
Need to remove the headlights and two bolts either side.
You also need to remove the plastic strips inside the opening in the front and should be able to pull forwards then.
Scott, Hi.........are you actually going to fit the front active spoiler to work? Or are you fitting it for looks?
I see you have an NA like myself, i brought an active spoiler,but only used the rubber lip, as the rest of the ali frame etc, add far too much weight imo.Very easy to fit the lip only for looks,with hardly any extra weight.See pic below, regards Al.
