94 JDM TT : Dreaded electrical faults + transmission {AUTO} misbehaving - Error code 64
JusticeTT
Hello all,
At kind suggestion I have started this up rather than continue it on in my 'hello' thread
(Which you may find a good hearty read, and also gives some background)
I appreciate the main issue I describe there relating to the transmission and the potential electrical symptoms have been covered quite extensively however I noticed that a lot of the historical examples point at or involve other error codes than the one I am tracking - such as 21, 42,
And unfortunately the given (or assumed ) solutions are often to replace the ECU when that might not have been the real solution, it was what was last suggested before the persons stopped updating their ticket...
While I am on the hunt to hopefully obtain one whether as a test unit or a replacement, I appreciate that's a challenge these days and it may not be the solution either
What the symptoms are
  • ECU code 64 - Defective lock up solenoid or short circuit-severed wire harness or short circuit
    • For a time it was also giving code 89 - Open or short circuit in communication circuit between TRAC ECU and ECM ECU // or TRAC ECU malfunction
      though that has since ceased[unknown resolution]
  • The vehicle does not downshift into Low from 2nd
    • While in Low, it behaves effectively as that it's in 2nd while the gear level is in Low position and physically shows on the dashboard as well
    • There are rare some occasions where should I leave it in L and start going along while it acts and behaves as 2nd, then it can down shift   -  seemingly random( catches you off guard when going ~ 20mph )
  • Overdrive sometimes does not engage consistently
    • This can occur on up shifting or while it's already in Overdrive; meaning while in drive the Overdrive button is engaged yet it does not up shift   <> conversely it can be in Overdrive, going along and it shifts down on it's own despite no change in throttle (or no noticeable change in throttle input)
  • Manu mode and slip control blink on dashboard
    • The frequency of this is not excessive
    • It can happen as soon as the vehicle starts, or sometimes later during a drive with no specific pattern of time for it to begin (or time elapsed)
    • On occasion the lights do not blink at all, and everything 'looks' as expected yet the 'physical' aforementioned issues persist, i.e. it can be showing as in Manu mode yet Low does not operate
Under what conditions they occur
  • Virtually any, however I have witnessed that the visual (the dash, lights etc) seem to be more prone to occurring when the temperature is on cooler side, say sub 20 celcius
When it happens
  • The physical element concerning Low and Overdrive is as soon as ignition and persists as a symptom until the car is turned off
  • The visual /blinking lights can happen as soon as the vehicle starts, or sometimes later during a drive with no specific pattern of time for it to begin (or time elapsed)
When it started to misbehave
  • About two years ago
    • I had it in a garage covered and had been sitting for a period of three months, with weekly or two times a month start up and idles to operating temperature as well as a slight reverse or drive movement a few feet to mitigate some tire flat spotting
      • I noticed the MANU button blink which caught my eye while sitting in the car while it idled one afternoon. When I pressed the button it hesitated to respond, seemingly. I left it and returned later in the year around February where I drove the vehicle and found no issue with the dash lights or the car itself
    • I had it out a handful of times that year, no issues
    • Come the next winter season(2023) I repeated the above and after a few engine turn overs during course of the months, I observed the blinking lights and hesitant manu mode button response
      • Eventually March rolled around and when I took it out to drive, the lights were still acting up but...no physical issues
      • I took out again not long after and then noticed the physical/drive issues began occurring
What you've tried to do to fix it
  • Research!
    • I have lots of wiring diagrams, fault code charts, saved bookmarks and pinned tabs. I even was trying to use the Wayback machine to be able to see posts on the Australian Supra forums which are no longer visible though appear in search results
    • Spoken to Chris Wilson about possible causes
    • Tried searching for reputable mechanic, specialist or electrical engineer that can look at the ECU in event Chris is not able to solve
      • Not yet located
  • Fluid checks of many types
    • I read somewhere that low coolant or coolant issues interpreted by the ECU might cause it to avoid lowest and highest gears as a somewhat safe measure
    • Transmission was the main one was aiming for, looks red to me
  • Alternator, waterpump and cam/timing belt replaced
  • Had the passenger side well carpet up and checked the outside of the ECUs engine and trac, to ensure nothing clearly obvious with the connections or wiring
  • Sourced ECU/trac code charts and run a code check
  • Checked fuses in the engine bay/compartment for any breaks
  • Reset ECU by removing EFI fuses
  • Look for another ECU to swap/test with
    • Not yet located
What effect those fixing attempts had
  • Currently no changes as a result
  • Has led me to better understand how the vehicle operates and potential causes - new avenues to explorer
Further notes, comments
  • The vehicle was adjusted to have a mph conversion, many years ago. I found what seems to be the wire for that coming out of an ECU and the connection looks OK (see attached)
What am I hoping to gain from this post
  • Other than the obvious - a solution, also about confidence in which avenue and path I am pursuing as I appreciate these types of issues may be a long journey
    • this could also be via ruling out any of the following
      • Dry solder on any part of the run from bell housing back up to the odometer connections behind dash
      • Transmission shifter wiring
      • Odometer
      • Delimiter/speed defender connection
      • Speed Sensor
      • Safety Neutral switch // "mlp sensor"
      • Bad transmission Solenoid 1 and/or 2
  • Meet/be introduced to some great persons along the way
Edited by JusticeTT (see edit history)
  • 2 months later...
I might have found a source for  both a main engine ECU and a throttle body ECU
Based off what I can gather, the majority of times there's a type of symptom(S) as I've listed above here, that's often going to be more on the Engine ECU side than throttle body
If I had to choose between the two, which to start with in particular to address ECU code 64 - Defective lock up solenoid or short circuit-severed wire harness or short circuit
Another thing I am concerned about is the vehicle has an immobilizer. Some persons say you can simply plug and play the ECUs (parts matching) and you won't have to do anything with the immobilizer
Others say you require a master key or be prepared to have to reprogram it
My fear beyond the hassle of reprogramming is that it triggers the alarm or something and I can't shut the thing off!
  • 1 month later...
Have obtained both an engine and a TRAC ecu.
Should anyone take a moment to see prior post about concerns with immobilizer (and of note, aftermarket alarm) that would be helpful
Additionally from a physical point of view
- I see some screws are in awkward spots
- Is the connector plug hard to remove
- Wiring delicate?
Any tips or tricks around removing the ECU unit(S)and replacing in relation to the above?
  • 4 months later...
The pink wire soldered is the speed signal wire : speed is used in various areas - it’s used to display the speedo ,and also used by the Ecu for speed limiting ,also used by Ecu for gear shift speeds . Often the speed signal is converted from km to miles - this removes or actually lifts the limiter . A chip is soldered in - behind the speedo or near the Ecu - it has an earth ,a power , and an “in” and “out” wire . These chips very often fail and the speed signal gets corrupted - with various issues . The ECU is used to send commands to the gearbox to shift and go in /out of OD -speed signal is used to calculate when and the ECU supplies a 12v to the gearbox solenoid - the solenoids in the gearbox can fail and do fail . The Ecu supplies 12 v via an internal resistor and the solenoids are earthed internally in the box . If 12v is supplied to say solenoid no 2 - the internal resistance has a voltage drop across it as current flows - the Ecu measures this volts drop …that’s how it decides if there is a fault - the voltage drop is not in limits - it could be too high or too low - it can’t tell ….hence the open or short diagnosis and commonnessnnn fault code . Hence ECU internal fails a possibility - you can swap the Ecu to eliminate , you can swap the speed converter unit ,you can measure the current flow and voltage to the solenoid and listeners to it - a positive click and compare between solenoids . The trac also uses the same speed signal . I would start with the converter ,they are real cheap electronics used in them but
  • Like 1
The lock up of the torque converter operates similar to the gear shift - there is a small clutch that is solenoid operated on /off - the Ecu calculates when it locks …..again a speed signal is used ,along with throttle position and the brake pedal switch (unlocks/locks with brake pressed ) once calculated if in lock or not it operates the solenoid …..it’s again a simple error calc to put up the fault code ie Ecu sends voltage and expects to see a drop in its internal resistor …open or short circuit - what it can’t do is work out if it’s calc is wrong ie a speed signal error or internal capacitor leak - it’s not that smart ! The speed signal is derived from the gearbox sensors (later cars used wheel speeds as well ) and speed is used on other cars like soarer for door locks ,suspension ,shift ,OD and steering - ALL can go wrong if the converter is wrong ! - you can measure the resistance of all the solenoids from the Ecu connector pins -so a quick easy check of wiring - but in the first instance a new converter may fix all issues inc trac
  • Like 1
