renegade Posted May 22 Share Posted May 22 the heater control works but the green light works then goes out but if you hit the dash round the controls it come back on for a bit. is this because it's just old or broken wire Quote Link to comment Share on other sites More sharing options...
Hamilton Posted May 22 Share Posted May 22 Dry solder(s) inside the heater control unit most likely. Fairly common now given their age but not too hard to fix. Quote Link to comment Share on other sites More sharing options...
chats Posted June 3 Share Posted June 3 Agree with Hamilton, defo dry solders on PCB board in the heater control unit. Happened to me, soldered the culprits and now working fine. Easy to do. Just use a very fine soldering iron tip. Quote Link to comment Share on other sites More sharing options...
