Headlight flash high beam issue
chats
Good morning
Grateful for advice. My headlights flash work when the stalk is pulled towards me as a quick flash but doesnt work when pushed away so high flash high beam stays on. All bulbs fine and no loose connection and fuses fine. Any advice, tuition etc will be very gratefully received. Thanks
Stupid question, but have you tried this with the dipped beam switched on? Because with the dipped beam not switched on, when you pull on the stalk to flash, the dipped beam AND main beam should flash. So you may think you have main beam flash, but really its the dipped beam you are seeing flash.
