Benjy Posted March 19, 2024 Share Posted March 19, 2024 As above, little red box, lives just to the side of the glove box. I believe the part number is 85980-14070 Link to comment Share on other sites More sharing options...
Dieter Posted March 19, 2024 Share Posted March 19, 2024 you would have to ask Toyota if this part is compatible with the Supra, this store offers such parts again and again https://www.2040-parts.com/1994-1997-toyota-corolla-door-control-relay-oem-denso-85980-12240-i1652310/ Link to comment Share on other sites More sharing options...
rider Posted March 20, 2024 Share Posted March 20, 2024 (edited) If it were me I'd take a punt on the Denso units of the same era having the same casing, plug connector and internals with the only discernible difference being the mounting bracket location, number of and shape. The Supra module has three mount locations so the Celica and the 90-92 model year Land Cruiser has a similar casing to the Supra under model number (land Cruiser 85980–60020) but both do use different shaped mounting brackets. My theory depends on whether Toyota supplied the mounts along with the module which would give a convenient explanation why the same module could then have several car model specific part numbers. I never tested this theory with actual purchases so it just remains a theory at this time. Edited March 20, 2024 by rider (see edit history) Link to comment Share on other sites More sharing options...
Benjy Posted March 21, 2024 Author Share Posted March 21, 2024 On 3/19/2024 at 9:52 PM, Dieter said: you would have to ask Toyota if this part is compatible with the Supra, this store offers such parts again and again https://www.2040-parts.com/1994-1997-toyota-corolla-door-control-relay-oem-denso-85980-12240-i1652310/ I just tried to contact them and it came back with something about it being out of date and impossible to contact. So no idea what that’s about. I would assume as long as it’s a 3dr such as a celica/starlet/corolla etc of the same era they’d do a similar job. Unless this controls windows aswell? Link to comment Share on other sites More sharing options...
Benjy Posted March 21, 2024 Author Share Posted March 21, 2024 11 hours ago, rider said: If it were me I'd take a punt on the Denso units of the same era having the same casing, plug connector and internals with the only discernible difference being the mounting bracket location, number of and shape. The Supra module has three mount locations so the Celica and the 90-92 model year Land Cruiser has a similar casing to the Supra under model number (land Cruiser 85980–60020) but both do use different shaped mounting brackets. My theory depends on whether Toyota supplied the mounts along with the module which would give a convenient explanation why the same module could then have several car model specific part numbers. I never tested this theory with actual purchases so it just remains a theory at this time. If it’s as simple as a mount, I’ll use zipties and number plate tape if needs be, as long as it unlocks my sodding doors! Lol Link to comment Share on other sites More sharing options...
mwilkinson Posted March 23, 2024 Share Posted March 23, 2024 Have you opened the module to see if it's a simple dry solder causing the issue? Link to comment Share on other sites More sharing options...
Benjy Posted April 4, 2024 Author Share Posted April 4, 2024 On 3/23/2024 at 10:30 PM, mwilkinson said: Have you opened the module to see if it's a simple dry solder causing the issue? I haven’t had 2 minutes to pull it out and have a look. Ebay one’s turned up so when I get a minute I’ll get on it Link to comment Share on other sites More sharing options...
