Cylinder Head Bolt Washers
Mzemzu
Hi...
Re: 2JZGTE with VVTi
and first Cat removed
Toyota list cylinder head bolts:
90910-02102
and cylinder head bolt washers:
90201-11018
as separate items, hence an additional cost.
I'll be replacing the full set of cylinder head bolts but is there any reason to buy the washers? First time for cylinder head to come off.
  • 2 weeks later...
If you already have a set, then just reuse them. I know there are tolerances for the headbolts but never heard of anyone checking for tolerances for the washers.
Would you not go for the ARP bolts instead of the toyota ones?
As Cillian has said, arp headstuds would be a good upgrade whilst the engine is apart.
Although with that being said, i know years ago arp had a bit of an issue with their headstud washers. They were manufactured a bit too small and so people used to bin them and use the oem washers with the arp studs.
That was years ago though and I'd assume that problem has since been rectified
