Probby Posted February 8, 2024 Share Posted February 8, 2024 Hi folks, I think @Bender had fitted a MKIII steering wheel but from what I can tell the airbag was never connected and working ? Has anyone fitted the newer sort of steering wheel and got that up and running ? Thanks, Link to comment Share on other sites More sharing options...
Bender Posted February 8, 2024 Share Posted February 8, 2024 Yes thats correct i fitted mk3 steering wheel but as i didnt have airbag from factory i couldnt do much in that matter anyway Link to comment Share on other sites More sharing options...
Probby Posted February 8, 2024 Author Share Posted February 8, 2024 Looked good @Benderam guessing no suitable airbag harness available ? Link to comment Share on other sites More sharing options...
Bender Posted February 8, 2024 Share Posted February 8, 2024 I think you are correct. But yes it gives car more modern look Link to comment Share on other sites More sharing options...
Burna Posted February 9, 2024 Share Posted February 9, 2024 (edited) I’ve fitted a retrimmed and modified Aygo steering wheel in the past (for sale at the right price), and currently have a retrimmed and modified Yaris wheel. Both with wired airbags. Edited February 9, 2024 by Burna (see edit history) Link to comment Share on other sites More sharing options...
Probby Posted February 9, 2024 Author Share Posted February 9, 2024 I think this is the route I'm going to go. I assume looking at the back of the airbag it's a single stage airbag which just needs the plug splicing in. The buttons can. Go as I doubt I'll find a clock spring which will work with the Supra and has that many wires ! How much would yours be sale for ? Might save me a job Link to comment Share on other sites More sharing options...
Burna Posted February 9, 2024 Share Posted February 9, 2024 On 2/9/2024 at 7:30 AM, Probby said: I think this is the route I'm going to go. I assume looking at the back of the airbag it's a single stage airbag which just needs the plug splicing in. The buttons can. Go as I doubt I'll find a clock spring which will work with the Supra and has that many wires ! How much would yours be sale for ? Might save me a job Expand No, they are twin plug, that will then need to join to a harness to fit the Supra airbag plug. I don't have a free clock spring wire as I wired the flappy paddles through it, along with of course the horn and cruise control, so used all my 6 connections. But you should have one spare, and in theory you could get the buttons working I'd let my Aygo steering wheel go for £500 + shipping. Link to comment Share on other sites More sharing options...
Probby Posted February 9, 2024 Author Share Posted February 9, 2024 Cheers , I shall grab a cheap Yaris one and have a play 1 Link to comment Share on other sites More sharing options...
rpslaughter1982 Posted March 2, 2024 Share Posted March 2, 2024 On 2/9/2024 at 7:23 AM, Burna said: I’ve fitted a retrimmed and modified Aygo steering wheel in the past (for sale at the right price), and currently have a retrimmed and modified Yaris wheel. Both with wired airbags. Expand How does the indicator cancelling ring (the three prong connector thing) fit to these wheels? Do you have to make a custom bracket? Many thanks Link to comment Share on other sites More sharing options...
Burna Posted March 4, 2024 Share Posted March 4, 2024 On 3/2/2024 at 8:02 AM, rpslaughter1982 said: How does the indicator cancelling ring (the three prong connector thing) fit to these wheels? Do you have to make a custom bracket? Many thanks Expand I don't quite understand what you mean when you say "the three prong connector thing". The movement of the clock spring comes from the plug position, so you have to make sure that moves in relation to the Aygo or Yaris steering wheel. Link to comment Share on other sites More sharing options...
rpslaughter1982 Posted March 4, 2024 Share Posted March 4, 2024 On 3/4/2024 at 10:24 AM, Burna said: I don't quite understand what you mean when you say "the three prong connector thing". The movement of the clock spring comes from the plug position, so you have to make sure that moves in relation to the Aygo or Yaris steering wheel. Expand Yeah tbf I described that terribly. I've attached a couple of pics, in the centre of the clock spring is a separate sprung connector that cancels the indicators when turning. The three prong connector is circled in the first pic. The prongs go into the grooves in the back of the steering wheel as shown in the second pic. Most of the newer steering wheels don't have the grooves for it to connect. Many thanks Link to comment Share on other sites More sharing options...
Burna Posted March 4, 2024 Share Posted March 4, 2024 Ok I understand what you mean now No you don't use those, you use the plug socket at the top, and pack around it as needed. 1 Link to comment Share on other sites More sharing options...
