1993 Supra 6speed
GTR RGT
95% Project. If I still have it into summer, I'll carry on with painting the body, redoing non-AN fuel lines, brakes and suspension, LINK ecu. Running in and mapping.
Purchased 5-speed rolling shell from a forum member, Mr Stark.
Shell had xxx miles. (Ill update)
Purchsed a 6speed engine, diff and box from Mr Keron.
All work was carried out by me including the rebuild, blueprinting, head and block skim, oversized bores, cross hatch, gallery cleaning. All except hot tanking.
Intake
Whifbitz intercooler piping
Whiftbitz intercooler 4"
NUKE blow off valve
KN air filter
Whifbitz 4" intake pipe
Boost controller that I cant remember atm
Electronics
AEM wideband sensor
AEM wideband gauge
Whiftbitz coilpacks
AEM air temp sensors\
Toyota water temp sensor
AEM ECU v2
Exhaust
Custom 4" down pipe(wrapped), mid pipe, HKS exhaust w/ vbands.
Greddy manifold
Precision 6766 turbo
Fuel
Twin AEM ethonel 340lph fuel pumps
Radium fuel hanger
Radium fuel filter
AN -10 fuel lines
AEM fuel pressure regulator
Whifbitz fuel rail
ASNU injectors (cant remember cc atm, enough for 900hp)
Head
Whifbitz cam gears
SRD stage 2 cam gears
Ferrea valves
Ferrea valve guides
Gates kevlar cam belt
Bottom end
King bearings
Manley pistons
Manley Rods
Manley wrist pins and circlips
BC valve springs
ARP studs
ARP rod bolts
Misc
Recaro bucket
ROTA force drift wheels
Brand new michelin pilot sport cup 2s
TRD 6Speed gearbox mount
6Speed release bearing, nose bearing, clips, washers.
HKS LA twin plate clutch
Silicone heater pipe
Billet fuel line mounts
Whiftbitz solid rear diff mounts
Custom prop.
Genuine toyota gaskets and seals.
Quick shift thingy.
Battery relocated to boot.
Bad bits would include:
Paint work, interior, and own labor I guess.  Build integrity can be verified at RK, I am a mechanical engineer by trade.
All receipts from Toyota, Whifbitz.
Owned for 8+ years.
Will add an MOT if needed.
Completely documented rebuild, pics and video.
£27k or I'd prefer bitcoin and would be open to deal with BTC.
Can be seen in Essex, or at RK tuning.
Reason for sale: Emigration.
Edited by GTR RGT
added more info (see edit history)
  • 2 weeks later...
  • 1 month later...
