Probby Posted January 28, 2024 Share Posted January 28, 2024 Hi there, I have an issue where I have no permanent live through to the stereo/antenna etc. I've traced it to the green/orange plugs (GC1/AC1) respectively. It looks like whatever bridges the orange plug to the green plug is down as I have no continuity between the two but have continuity between the battery and and the green plug and the orange plug to the antenna/stereo power. The junction box is in the passenger side footwell however it's pretty tough to move around. Does anyone knows what I need to remove to get it out ? I've disconnected all the plugs and taken out the bolt but wonder if there are any other hidden fixings ? Thanks in advance Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted January 28, 2024 Share Posted January 28, 2024 There bolts and a large slide tab at the top that needs to be released before you can pull it out fully iirc Quote Link to comment Share on other sites More sharing options...
Probby Posted January 28, 2024 Author Share Posted January 28, 2024 @Mike2JZcheers I've just seen your message. I ended up using a bore scope to find the top slider you were on about. As soon as I pushed the green connector out of it the blue/yellow wire appeared - crimped bit has corroded leaving the pin in the plug. Id really like to re-pin it but that's gonna be an absolute arse to get to. I'm also not sure what pins those plugs take ... Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted January 28, 2024 Share Posted January 28, 2024 Take a photo of it, might have a terminal for it Quote Link to comment Share on other sites More sharing options...
Probby Posted January 28, 2024 Author Share Posted January 28, 2024 Cheers Mike, It's the green plug in shot here. Like I say the bottom right pin is still in place so it looks grand from the front. If you know what tool you need to get them out and what crimp they are I'll happily order some. Equally, am hoping they are similar to the ones on my Subaru so I can pinch one off the spare loom there Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted January 28, 2024 Share Posted January 28, 2024 Is it the male or female terminal you need? Quote Link to comment Share on other sites More sharing options...
Probby Posted January 28, 2024 Author Share Posted January 28, 2024 It's the male @Mike2JZI'm after. Quote Link to comment Share on other sites More sharing options...
Probby Posted January 30, 2024 Author Share Posted January 30, 2024 (edited) Thought I'd update this for reference. Anyone who's interested: Part Numbers (green plugs in picture) 90980–11416 - Female 16 pin plug 90980–11415 - Male 16 pin plug Male/female pins are Sumitomo TS / DL / SL 090 Male Terminal 0.5 - 1.25 Can get them from here: https://www.automotiveconnectors.com/sumitomo-09023mm-male-contact-03-125mm.html Edited January 30, 2024 by Probby (see edit history) 2 Quote Link to comment Share on other sites More sharing options...
